VY LS1 pinout help
Discussion in 'VY Holden Commodore (2002 - 2004)' started by dj_gardner007, May 19, 2013.
  1. dj_gardner007
    dj_gardner007 New Member
    NSW
    VX SS LS1 Manual, VL LS1 Manual Wagon
    Hi,
    I'm after the pinout for the main engine connector plugs that connect the engine loom to the dash/fuse box loom.
    I am putting a VX LS1 into a VL and will be running a full VY gauge cluster.
    I have the full diagrams for the VX side of the wiring, just need the VY wiring diagrams to be sure I'm joining the correct wires to each other.
    The VT/VX has 4 connectors, 3 between the driver's side strut-tower and firewall and the 4th above the brake booster. The VY has 2(AFAIK), 1 inside the car near the glovebox and 1 near the passenger side headlight.
    So if anyone has the VY LS1 diagrams/pinouts that would be much appreciated if i could get a copy.
    Thanks,
    Dave
  2. MRNICK
    MRNICK LS1 LOVE
    Newcastle, NSW
    VYII SS UTE
  3. dj_gardner007
    NSW
    Thanks.
    But more what i was after was joining the VY Dash/Main Fusebox Loom to the VX Engine Loom.
    I've seen a lot of forums about people putting a full VY dash into a VT/VX but nothing on the wiring side of things, other than swapping to a VY engine loom aswell.
    I was hoping for something similar to this for a VY, this is from the VX Service Manual:
    As it shows which wire is in which pin, but also the number as there are double ups of wire colour but each a different circuit.
    Thanks ,
    Dave
  4. dj_gardner007
    NSW
    OK, looks like most of the wire colours match up. I'll check them with a multi-meter to make sure they are what they are supposed to be, just to be on the safe side.
