DarkCrystals
- Jun 15, 2015
- 11
- 0
- 1
- Location
- Auckland, New Zealand
- VZ Clubsport M12
Hi All,
I'm in the middle of a cam change on my VZ LS2 Clubsport - Manual.
The LS2 has stock 243 heads. Headers and exhaust done, OTR XAir intake. I do plan on aftermarket heads and Fast 102 in about a year.
The cam I have installed is Comp Cams 277LR HR13. She's 227/235 @0.50 (advertised is 277/285), 113LSA, 0.614 intake lift and 0.621 exhaust lift. Comp Cams part number is 54-458-11
I have also installed Comp Cams Timing kit 3518KT.
Next on the list is to install my Comp Cams 26926 dual valve springs (with Comp Cams toolset retainers, seats, valve stem seals, locks). I will run the stock lifters till I eventually get the new heads. Pushrods will be purchased once I work out the length (likely 7.4inch but going to verify just in case). Am using stock rockers too.
Now that I have installed the bloody cam, I'm starting to get worried about my PTV, which I will check with check springs and dial indicator on intake and exhaust - still a week or so away from this. What are peoples thoughts on possible PTV issues with this cam? Is a lot of work just to see i'll have too little clearance and possibly have to remove and install another cam. I can advance/retard the timing gear (adjustable hex nut) to increase either I guess... Comp Cams themselves said they have seen 'no real issues'... hmmm.
