impulsesv6
Alloytec Garage
- Dec 26, 2006
- 601
- 5
- 0
- Location
- brisbane, QUEENSLAND
- A quick Alloytec
here is some info on the 5spd man:
Hydra-Matic 5L40-E Transmission (M82/MX5)
Type: five-speed rear-wheel-drive, electronically controlled automatic overdrive transmission with torque converter clutch
Engine range: 1.8L - 3.6L (M82/MX5)
Maximum engine torque: 254 lb-ft (344 Nm)
Maximum gearbox torque: 494 lb-ft (670 Nm)
Gear ratios:
First: 3.42
Second: 2.21
Third: 1.6
Fourth: 1
Fifth: 0.75
Reverse: 3.02
Maximum shift speed: 6500 rpm
Maximum validated gross vehicle weight: 7716 lb (3500 kg)
4-position quadrant: P, R, N, D & DSC +/-
7-position quadrant: P, R, N, D, 4, 3, 2
Case material: die cast aluminum
Shift pattern: (3) three-way on/off solenoids
Shift quality: variable bleed solenoid
Torque converter clutch: pulse width modulated solenoid control
Available control features: internal mode switch
reverse lockout
multiple shift patterns (selectable or adaptive)
engine torque management on all shifts
altitude and temperature compensation
adaptive shift time
air conditioning cutoff
Oil Life System
OBDII/EOBD
Converter size: 245 mm (reference)
258-mm dual plate (diameter of torque converter turbine)
Fluid type: DEXRON III
Transmission weight: dry: 74.5 kg (175 lb)
wet: 82.5 kg (186 lb)
Fluid capacity (approximate): dry: 8.5L (9.5 qt) (with 245mm)
Pressure taps available: line pressure
Assembly sites: Strasbourg, France
what are the 4spd auto and 6spd man box numbers?
Gear ratios:
First: 3.42
Second: 2.21
Third: 1.6
Fourth: 1
Fifth: 0.75
Reverse: 3.02
reverse lockout
adaptive shift time
Oil Life System
OBDII/EOBD
