B
bluevz
Guest
just wired up trailer lights.... the left indicator not working!! It turns out after some fault finding the wiring loom in the car hasn't been installed properly! the yellow wire in the cars trailer connector is floating loose at the other end and not connected to anything. all other light work ok r-indicator, tail, brakes. So where does the yellow wire with its single wire connector plug in. I cant find any left indicator voltage on the multipin connectors at the end of the trailer loom. Any help, wiring diagrams etc would be appreciated. Thanks Dave
