Car Audio Factory Outlet
- Dec 1, 2006
- 450
- 3
- 0
- Location
- KENMORE QUEENSLAND
- Website
- www.caraudiofactoryoutlet.com.au
- VK BROCK Group "A"
Yer! that would be great.. it cant be any bigger than 435mm in width 480mm in height and 210mm deep.. those mesurments give me way more than what i need it to be..
.435*.480*.210 = 0.043848
cubic meters to Cubic feet = 1 cubic meters = 35.3146667 cubic feet
= .043848 * 35.314667 = 1.5484775 cuft
So you need to drop .7284775 cuft out of the internal volume
Which means that put an internal board in to reduce the volume not from the height!
therefore if you go to an internal volume of 330mm * 330 mm * 210 mm in height which means you are not adjusting your height will still give good clearance for the Subwoofer basket etc.
and give you a spot on volume of .8 cu ft
PLEASE on that is the internal measurement so if you are using 16mm mdf then you need an area from inside of board to inside of board of 346mm * 346mm
Hope this helps and answers your question
You can still keep your external measurement of 480*435mm but you will have another set of boards internally so it is the measurements above
