Wipers
Discussion in 'VY Holden Commodore (2002 - 2004)' started by djohns, Feb 15, 2010.
  1. djohns
    djohns New Member
    VY
    Guys
    I need to replace the wipers, do I just get one from Supercheap or should I get one from Holden spares...?
    Please advice
    Thanks
  2. PaulSV6
    PaulSV6 CHE Tuned 156.8rwkw
    Castle Hill
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Ive gone to Holden, sursprisingly they dont charge much.
  3. alien
    alien New Member
    Tullamarine, Vic
    03 VY Supercharged 3.8L
    Do you mean wiper refills? If so:
    Just goto KMart or any auto store? For a few extra dollars they should also have Teflon coated windscreen wipers which usually last around double the life of others.
    If you mean the whole wiper blade (refill and holder) assembly, then yea, Holden don't charge much. But you can still get them anywhere too for roughly the same amount.
  4. whitey66
    whitey66 Member
    VY S Sedan
    Put some Bosch Aerotwins on it,after using them you'll never use anything else.
    They are the one piece wiper similar to what VE commy's use,and can be found at Supercheap.
    You'll need a BBA500 and a BBA550 for the VY.
  5. colgf
    colgf New Member
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    NO , Supadear dont stock them any more , you have to Order them from AutoBarn. Well worth the extra bucks , about $80 a pair but Sup good , bosch quality & look smick too , easy to fit instructions on packet. :idea3:
  6. maccasparks
    maccasparks New Member
    Tauranga NZ
    VY V6 Wagon
    Yeah BOSCH AEROTWINS best blades ever!!
  7. vywgn
    vywgn New Member
    1967 Holden HR Premier Wagon / 2011 VEII SV6 Sedan
    i agree, had them on the wagon for just over 2yrs and still worked brand new
  8. VY Woodsy
    VY Woodsy New Member
    VY s-pack 3.8L
    Alright you can either just buy standard refills or go with the "flex blade" made by triton i believe (find them at supercheap, even have a book to show your size)....the flex blades are sweet as and simple to install (Highly recommend and about $60 for the both), although a little pricey...otherwise just go with some silicon refills
  9. M100
    M100 New Member
    QLD
    VY Acclaim wagon
    I agree on the Bosch aerotwin... i was lucky to source the for $6 each just before they shifted over to triton... So I bought 3 pairs:beer chug:
  10. TMM
    TMM OEM+
    VIC
    VY Berlina S2
    Bosch Aerotwins for sure. And get some 303 wiper blade treatment to keep them in tip top shape.
  11. a1k3m1
    a1k3m1 New Member
    Central Victoria
    2003 VY II S-Pack 25th Anniversary
    im just wondering would the VE commodore wipers fit onto the VY? .. because i cant seam to find anywhere on ebay or the auto shops that sells them, but i can easily find ones for the VE's .. :(
  12. whitey66
    whitey66 Member
    VY S Sedan
    No,they definitely won't fit.
    Dealer locator here
    Bosch - Aerotwin Wiper Blades
  13. mrhotdog
    mrhotdog What Would Jesus Do?.....
    Adelaide, South Australia
    2003 VY S1 Acclaim
    ok, bit stupid qn, but i bought replacement wipers today (the assembly) but i cant seem to get the old ones off. with my VS they used to come off easily when replacing, so whats the trick with the VY?
  14. whitey66
    whitey66 Member
    VY S Sedan
    Lift the arm away from the windscreen,push the small clip on the plastic U-shape fitting and slide it out of the arm (back towards the windscreen).
  15. mrhotdog
    2003 VY S1 Acclaim
    thanks whitey, worked a treat
  16. a1k3m1
    a1k3m1 New Member
    Central Victoria
    can anyone find these bosch aerotwins on ebay for a VY? .. coz im stuffed if i know where to look on there lol
