Jvbking
- Jan 19, 2023
- 3
- 2
- 3
- Age
- 27
- Location
- NSW
- WM Caprice
Hey guys.
My Dad recently bought a 2007 Caprice that I'm helping him fix up which looks like it's had a bit of water inside. The RSE and rear climate doesn't turn on and the timing chain is about to fall off, but the biggest issue I'm having so far is the damn mirrors.
I've swapped out the drivers side mirror with a working one, but when I plug it in it is stuck going in one direction until the worm gear starts slipping. Testing the plug shows constant 12v on one of the motor pins
I've checked the fuse boxes, swapped out the mirror buttons on the console, new BCM and I've got the 10-way seat memory module on the table which is testing fine.
Is there a mirror control module or some relays hidden under the dash somewhere? I've seen people mention there being one behind the cluster and one under the door trim, but no luck so far finding it.
