Wraiths 2004 VZ Berlina V8
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
Ah ok fair enough. I'm already bored of the power. I want to skip cam, heads etc and move straight to boost. If only the bank balance agreed.
Boost breaks. NA no attachments.
My Clubby is my daily, and I'm quite happy with 330rwkw. Maybe one day build a big NA stroker iron block.
I'm over boost, work with it every friggin day.
Bank balances, the death of car enthusiasts...
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
You have a better motor and more mods though. I started at a disadvantage to begin with with the 20kw power difference between this and an SS.
wraith
Demonicaland
Well MCAI mostly done. What a bitch of a job on a VZ. Dyno tomorrow will post up the results.
exanVZ
VZ Thunder
Coming along nicely, probably pretty similar to my SS now. Keen to see how it goes on the dyno, so you've done intake, catback and tune so far? I'd chuck in a guess of about 295rwhp on a mainline dyno.
wraith
Demonicaland
Yeah high flow panel filter. 2 hole with MCAI. Twin 2.5 cat back. Tune is the only iffy thing really being an eBay special. That's the main reason I am running it up to make sure the AFR is safe.
wraith
Demonicaland
Well I'm pretty happy with that result. Tuner said AFR was spot on. He was quite impressed for a $350 dollar eBay special and said he wouldn't be able to get much more if anything.
K-BAGZ
De Plane! De Plane!
Far North QLD
Not bad, not bad at all. You and Dem would be loving it!
wraith
Demonicaland
Yeah it's a lot of fun that's for sure. Have to be real careful with the throttle though. Blip the throttle at 40 and before you know it you are doing 80+
K-BAGZ
De Plane! De Plane!
Far North QLD
Next is fuel usage.
wraith
Demonicaland
Fuel usage is scary. Compared to the clubby it's ridiculous. Clubby you can have fun in and have fuel left. In this you have fun and watch the needle drop.
