carb sold as is I dont have time to rebuild it. Im devoting my time to a V8 conversion on my good car.
Carbs are easy enough to rebuild, last kit I bought for a varajet was $28, weber shouldnt be much different. The kit comes with instructions as long as you pull it appart and take note where everything goes its a piece of cake probably take a couple of hours if that, just dont skip things or try to cut corners esp take your time getting your float level right
I tried a few different float positions on the varajet on the car im driving atm and found 7mm worked better than the recommended 8mm, unless the ruler was out
I have heard the holley carbs dont go so well on the 202s could have just been the size or something they were using but, if your chasing power just go EFI dont waste time with a carb.
If you want to put the weber on just buy a adapter plate wont cost much. I could see the whole job buying the carb, rebuild kit &adapter plat costing about $100-$120 all up
