soleit
- Oct 16, 2011
- 153
- 5
- 18
- Location
- Laurieton
- 09 VE SS-V
I've searched for the past few weeks and find heaps of threads about this issue but they all have the engine light on. This is my 09 SSV wagon. My abs and stability off warning started when I backed the car out, put the handbrake on and suddenly up flashes abs off and stability control off. Figured I may have bumped the stability switch, pressed it, nothing. Turned the car off, restarted and came back on as soon as the system check was finished. Every time I drive it does it, as soon as check system is done 3 beeps and the warnings and ESP OFF sits on the bottom of the screen. I can still use the trip button to flick through (I like the speed on screen) and ESP OFF still shows, abs light on top right of dash, brakes work fine and nothing seems to be wrong. Bought new wheel speed sensors just in case (not installed, not looking forward to it), would they fix this, new battery, what?
I ran my obd reader (torque pro on android) which found nothing, done a code clear anyway but still the same.
If it makes any difference, only mods done so far are tailpipes and VCM MAF CAI with the new adaptor for the MAF pipe to prevent engine code errors.
