V
Vzniko
Guest
hope all worked out for you?????
Not exactly - Make sure you get new spark plugs as well - apparently damaged coil packs will damage the spark plugs with them.
I only changed the coil packs - and after 2-3 days of no problems, the shaking/rough idling has come back - I will take out spark plugs and clean them -It better be the spark plugs - ITS DRIVING ME NUTS.
I tested (with a multimeter) my old and new coil packs and I came up with some interesting values
Anyone with a repair manual that can have the look on the values (in Ohms) for the VZ coils.??
Here is how i tested, however all of them are giving me different readings.
I just replaced all 6 of them. It has 4 metal pins I tested the 2 middle ones first and then the left (1st) and 3rd one. (The other combinations gave me no reading).
OLD COILS - in MEGA ohms
pin tested XxXx (1st and 3rd) Two middle pins xXXx
1 - 5.22 11.94
2 - 5.00 11.78
3 - 0.46 No reading (This one is finished)
4 - 5.02 11.87
5 - 5.05 11.92
BRAND NEW COILS
1 - 10.00 16.05
2 - 08.57 17.33
3 - 11.96 13.05
4 - 08.71 16.55
5 - 08.00 15.37
6 - 08.21 16.14
As you can see the values are ALL over the place, however I deducted that the two middle pins need to be 13+
and the 1st-3rd pin more than 10+
Anyone that can give me some values to work with??
