Results 1 to 6 of 6
Thread: Jesse SV6
    04' VZ SV6
    Sep 2011
    Rinwood North, Melboure, Victoria
    Default Jesse SV6
    These are the pieces that I'm looking for only thicker to fit over the Black T section above it on the B pillar Trim. I took some shots of the space in the car just to make sure you have the correct one. Also wondering if you have a Black passengers side sun visor to fit a VZ.
    Cheers.
    [IMG] [/IMG]
    You drive a FORD? That's O.K we all make mistakes..
    N/A
    Aug 2011
    Yep, this is the exact piece I had thought. I had an inkling they may have changed for the Calais, apparently this is not the case. They never made thicker pieces, nor do I believe they ever came out with any cloth covering. They were always bare plastic, varying in color. I can help you out with that piece, but it would be the exact same as your original, which to me doesn't look broken.
    Will PM you in regards to the visor, have to find one.
    VZ SV6
    Aug 2010
    Quote Originally Posted by TC Dylan View Post
    I have done the change to a Calais black roof lining and yes the B pillar plastic pieces are different for the Calais. They are thicker to accomodate for the adjustable seatbelt component in the top cover.
    I got mine off the local Holden dealer but had to specify they were for the VZ Calais to get the right ones.
    N/A
    Aug 2011
    Appreciate the extra info, haven't wrecked a VZ Calais so would have no clue. As per previous statement, haven't wrecked a VZ Calais, so can't say I would have any. Same with the visor unfortunately, I'll have a quick look in the crevices of this joint though, never know what will turn up.
    04' VZ SV6
    Sep 2011
    cheers mate would appriciate it.
    VZ SV6 Sedan & VZ SVZ Wagon. RIP: VZ SS Ute
    Oct 2006
    Brisvegas
    Quote Originally Posted by 71Bogan View Post
    My apologies for the thread dig, I just picked up a complete VY calais headliner and pillar set - except for the lower b-pillar trims... silly me assumed they would be the same and didn't get them...
    Do you remember the cost of these from the dealership?
    Also did you just fix the adjustable trim piece at a certain height? Or is the SV6 seatbelt able to be adjusted?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
