Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: keep blowing up vt v6s
    vt speedway car
    Nov 2010
    mildura vic
    Default keep blowing up vt v6s
    hey guys need some help my vt ecotech engines keep shitting themselves in my street stock and it always seems to the conrod bearings, what is going wrong, or what am i doing wrong?? it always has good fuel and oil pressure
    acarmody is online now Donati..Whoa Green
    VX Berlina
    Apr 2007
    You have it near the rev limiter to long and the Ecotecs will throw big ends fairly well.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    Now with my very own Tech2....YAY.
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    so stop doing skids in first gear!
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    too much timing and rev limiter will kill one quick smart at revs . are you just fitting stock vt engines or built ones.and are you running the 808 vn ecu's
    VL Commodore
    Dec 2008
    Do the Ecotecs not like revs over 5-6K, Never knew that would kill them quick I should stop thrashing mine, i haven't done any mods.
    Is it any weakness in the engine that makes it not like those revs, oil flow?
    VX Berlina
    Apr 2007
    The valve train isn't the sturdiest thing in the world, and thrown big-ends is fairly common in Ecotecs. Remember these engines were built to be an economical engine to move a family sedan not a burnout engine.
    VT super6
    May 2006
    Can we get some more info?
    When you say "street stock" are we talking standard road car or a class of racing?
    what type of driving? You doing skids? hitting the limiter? very high speeds or fast cornering?
    Manual or auto?
    What fuel are you using?
    immortality's Avatar
    HSV VS Senator, VN V6 T5, VS V6
    Apr 2006
    Auckland NZ
    with street stock i would take it to mean that you mean speedway/ circle dirt track stuff.
    although you may think that you have good oil pressure, constant sideways action/ throwing the car into corners on/off the gas etc gonna give you oil surge. any particular rod/rods that keep eating the bearings and throwing a leg out of bed?
    Body by Holden, Soul by Brock
    the Legend will live forever
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    Surely Holden would put the rev limiter at an rpm that is deemed safe for the engine... However this doesn't mean to just keep bouncing off it, but I'm sure the engine can safely handle revving closely to it before you feel the need to change gears!
    VT
    Apr 2005
    QLD
    They're cheap as shit, just keep changing them ha ha ha ha
    OR!!!
    Screw a 2 inch block of timber to the back of the accelerator pedal
    vt speedway car
    Nov 2010
    mildura vic
    Default help
    Quote Originally Posted by TappetHead View Post
    Manual or auto?
    hay its a dirt speedway car . we just race round n round both ways. its got a vn t5 preium we run in 2nd n my diff is 292
    vt speedway car
    Nov 2010
    mildura vic
    VT super6
    May 2006
    vt speedway car
    Nov 2010
    mildura vic
    Angry Sump
    Quote Originally Posted by tappethead View Post
    have a chat with asr about a sump, i know they have them in stock
    hay mate cant use diff sump the class i race in dose not allow it thanks ne way
  15. #15
    Apr 2006
    Auckland NZ
    try over filling the sump a little. still talk to ASR, maybe they can make some baffles for the sump to combat oil surge etc
    maybe also fit another oil pressure switch that is set for 40psi attached to a shift light or some similarly bright so you know when the oil pressure is starting to drop before serious damage is done because the factory oil pressure light doesn't come on until oil pressure drops to 6psi and if you have the loud pedal mashed into the floor the damage has already been done at that point.
  16. #16
    VT super6
    May 2006
  17. #17
    VT
    Apr 2005
    QLD
    Overfilling could cause more problems than it solves, due to foaming.
    Baffles/trapdoors could be a step in the right direction though.
    Tried throwing a set of different bearings in it before you sodomise the engine?
  18. #18
    vt speedway car
    Nov 2010
    mildura vic
    Apr 2006
    Auckland NZ
    the VN loom/808 ecu uses 1 knock sensor. are you running a standard tune? if so it will have to much timing for a ecotec motor and it will ping which will also kill your bearings
  20. #20
    vt speedway car
    Nov 2010
    mildura vic
    Quote Originally Posted by immortality View Post
    hay mate thanks 4 that wots the best way 2 retard timeing
  21. #21
    vz wagon
    Aug 2006
    Wild west of Melb
    Yeah best bet is to run the knock sencer mate and are you doing anything with the back of the harmonic balancer ?
  22. #22
    vz wagon
    Aug 2006
    Wild west of Melb
    standard sealed computer from vn/vp. there is a few different tunes in the standard comp try runnin it on the dyno with a couple different computers see if ya can find 1 thats got a better tune in it Jase.
  23. #23
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    round track sump need cuctom baffles to stop oil running away from your oil pick up would be my guess
    that or its as simple as dirt getting into motor trhough intake into oil then eventually into your bearings
    note: baffles are internal and cant be seen
  24. #24
    vt speedway car
    Nov 2010
    mildura vic
    Quote Originally Posted by db_notso View Post
    were do i get baffles from???
  25. #25
    vt speedway car
    Nov 2010
    mildura vic
    Quote Originally Posted by Clutchy View Post
    wot can you do with the harmonic balancer ?
LinkBacks (?)
  1. Air-con blowing hot after a while
    By miker75 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2010, 11:18 PM
  2. Fan Blowing hot air?
    By GMHCalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2009, 12:13 PM
  3. Fan/Air con blowing down
    By Mungrel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2008, 12:59 PM
  4. Air box blowing up
    By goodyear in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2007, 08:42 PM
  5. vn a/c & fan not blowing air :(
    By STYALR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2006, 09:19 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
