Results 1 to 6 of 6
Thread: injectors
    vt speedway car
    Nov 2010
    mildura vic
    Default injectors
    hay gys are vt supercahrged injectors bigger than standard ones
    Nov 2004
    vt speedway car
    Nov 2010
    mildura vic
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    miniscule performance increase even with perfect motor and top qaulity fuel why are you wanting to change on the standard vt?
    and i have heard off people using magna injectors too not sure off what model though
    but those people had a custom tune bigger intake and exhaust
    immortality's Avatar
    HSV VS Senator, VN V6 T5, VS V6
    Apr 2006
    Auckland NZ
    changing injectors to ones with a greater flow then standard on a stock motor = fail
    people have used the magna injectors (with the same flow rate) because they have a better spray pattern (then some of the older injectors) which should promote better combustion however the VT uses EV6 style injectors which should be just as good
    check here for flow rates/rated pressures/impedance
    http://apps.bosch.com.au/motorsport/...linjectors.pdf
    vn v6 up to 10/90: 0 280 150 901#
    vn,vp,vr v6 from 11/90: 0 280 150 960
    vs v6: 0 280 150 973
    vt,vx,vy v6: 0 280 155 777
    vs,vt,vx,vy v6 s/c: 0 280 155 868
    vl grp A v8 5.0l: 0 280 150 901
    vn v8 5.0l (incl vn & vp clubsport): 0 280 150 901
    vn grp A v8 5.0l: 0 280 150 706
    vp,vr,vs v8 5.0l (incl vr & vs clubsport): 0 280 150 960
    vt v8 5.0l (incl vt clubsport): 0 280 150 973
    vr,vs,vt 5.7l(215kw gts): 0 280 150 775
    vt,vx,vy v8 ls1 (incl all ls1 clubsports): 0 280 155 931
    vt,vx,vy,v2 ls1 gts (300kw): 0 280 155 890
    Body by Holden, Soul by Brock
    the Legend will live forever
    vt speedway car
    Nov 2010
    mildura vic
    thanks gys
  1. Replies: 4
    Last Post: 13-11-2010, 08:16 PM
  2. [VIC] 6 x 36lb Bosch injectors - VS-VY Super6 injectors
    By BLC in forum Parts And Other Items For Sale
    Last Post: 13-03-2010, 04:45 PM
  3. Injectors
    By djvass in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2008, 06:54 PM
  4. Injectors?
    By Torniquet in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-07-2006, 10:13 AM
  5. wtb v6 injectors
    By na3point8 in forum Swap / Wanted to Buy / Trade
    Last Post: 08-12-2005, 09:19 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
