+ Reply to Thread
Results 1 to 16 of 16
Thread: Plenum swapping between ecotec models - Need help with sensors/valves
    VSSECO is offline Underdog rebuild VSSECO Executive
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    Default Plenum swapping between ecotec models - Need help with sensors/valves
    Hey guys. OK so as everyone knows, the early ecotec plenum/inlet manifolds are different to the later VT VX VY models... SO, whats required for me to install a complete VT manilfold and plenum on my VS??? If i'm using the complete upper and lower manifold then will the PCV valve be functional? What about the other sensors. I cant remember what the new one one the VT model is called.
    Who's done the swap?
    *** FOR SALE ***
    4.2L Buick V6 Billet Stroker - Built for big boost
    HUGE $$$$ SPENT - Selling well under half of the build cost
    http://cgi.ebay.com.au/ws/eBayISAPI....STRK:MESELX:IT
    VS II L67 M5 & VT II International Calais L67
    Aug 2008
    NSW South Coast
    Yep i've done it. I sourced a brand new vx manifold and plenum which I match ported and polished and installed on my vs.
    The vt manifold will not have the provision for a coolant temp sender (the small brass one that works your temp gauge) which on the vs is threaded into it just under the thermostat. So on this same spot on the vt manifold you are going to have to drill a hole and tap a thread for it. It is a tapered thread, not parallel, so the further you screw the sender into it the tighter it gets. I'm almost certain the thread is 1/8NPT. The thread for the coolant temp sensor (the larger one also into the thermostat housing) is the same between models so just swap the sensor over from your vs.
    The plenum is also different. On the back side of the throttle body flange there will be a hole that is roughly 15mm diameter from memory that on the vt-vy models is hooked up to the EGR valve system. This does not exist on the vs models so you will need to fill the hole somehow. I welded mine, but if you dont have the gear to do this you could also cut a thread in the hole, and then thread in a bolt with thread sealant to blank it off.
    The PCV valve setup is slightly different, but does function just the same. The minor difference being in the point at which the crankcase hydrocarbon gases are fed back into the plenum. On the vs plenum this hole is in the back lefthand corner, whereas on the vt-vy plenum it is located on the right hand side in the centre of the plenum. You will see on the top machined face of the manifold that there is a little channel for the gasses to pass through to allow this slight difference. All this change does is makes re-combustion of these gases a little easier as they are drawn into the manifold ports with the air intake through the throttlebody. That probably sounds a little confusing but you will understand once you compare the two.
    The valley/manifold gaskets are the same on all ecotec's, but the manifold to plenum, and throttlebody to plenum gaskets are different on the vs to the vt-vy as the vs uses o-rings on these, whereas the vt-vy uses a metal gasket on the manifold to plenum joint and a paper gasket on the throttlebody to plenum joint.
    While your at it i'd also recommend using the vt fuel rails as they are solid steel piping with no flex-joins like on the vs which have been known to leak.
    Hope that helps
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    Thanks heaps, thats exactly what I was after! All makes sense to me! ...and EGR is what I was trying to remember, I figured i'd have to weld it up. Totally didn't think about the temp sensor tho, thanks for the heads up.
    Only thing i'm not sure on now is the mace insulator... The PCV hole will be in the wrong spot wont it??? I dont remember ever having to specify vs or vt to mace when I bought it???
    *** FOR SALE ***
    p_schrapel is offline soon to be big turbo p_schrapel Executive
    vs commodore
    Nov 2008
    hey guys im just wondering is there any differences between the vs to vy manifolds as in performance wise. i know EGR is different.
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    I was wondering myself. I don't think there would be much of a difference in terms of how well they both flow.
    *** FOR SALE ***
    Aug 2008
    NSW South Coast
    Quote Originally Posted by VSSECO View Post
    Your insulator from Mace will be fine and will work on all ecotec's. The location of the PCV valve in the inlet manifold remains the same, its just a small channel on the underside of the plenum that re-routes where in the chamber the gases are released
    Aug 2008
    NSW South Coast
    Quote Originally Posted by p_schrapel View Post
    Unfortunately theres not really any performance benefits in the upgrade. The manifolds flow the same but I have heard that the later plenums are slightly better in terms of distribution when running boost.
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    Thanks again Cander24, your the man
    *** FOR SALE ***
    Aug 2008
    NSW South Coast
    No worries, glad to help. I just found this pic too so thought i'd post it up for you. The red arrow indicates the PCV valve channel that I was talking about which does not exist on the vs manifold. The hole in the vs plenum lines up directly above the PCV valve/spring setup in the manifold, whereas on the vt-vy it lines up directly above the end of this channel. Hope this is helpful.
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    Ah, I've got ya. Thanks for the pic, that clears up some things. So, I've got myself a spare manifold now but I'm actually confused as to what model it has been removed from...
    As you can see in the pics, my manifold has:
    - Holes for both temp sensors
    - O ring gaskets between plenum/manifold and plenum/throttle body
    - PCV on the side of the plenum, not re-directed to the plenum neck
    All these things would indicate that the manifold is obviously a VS manifold, right, BUT if you look at the pic of the plenum neck you will see that it has an EGR hole in it. That confused me a lot!
    So, is it possible that it has come from something like a VS ute (which is a VS model but built years later when EGR was being used)??? IF SO... do you think that the VT fuel injectors with better spray pattern were used? (The injectors from it have 4 holes in a sqare arrangement)
    Doesn't matter really but I'm just curious. I'm just gonna have to weld up the EGR hole... at least I dont have to drill and tap temp sensor holes.
    *** FOR SALE ***
    Aug 2008
    NSW South Coast
    Ok well that really is strange. Only possibility I can think of is that setup has been retrofitted to a VT onwards at some point??? All the feature there suggest VS, i.e pcv location, gasket types, coolant sensor/sender, metal body injectors, fuel rails. Does the egr valve hole look original?? I suppose it does'nt really matter as you say because all you have to do now is weld up that hole to get it to work for you. The VS utes (including the later series 3 models) never ran the egr valve setup. The VT body was the first to use this. Likewise with the injectors, vt was the first to use the plastic bodied injectors (which have 4 holes in the pintle cap). Are you going to port-match and polish this manifold setup or something a little more customised?
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    The EGR hole looks very original... I've attached a pic of the other side of it. Yeah the injects are metal bodied but as I said they've got 4 holes in the cap???
    I've been throwing around the idea of cross ramming it (in which case, all plenum features will mean squat anyway )... but realistically that is gonna be an expensive and time consuming exersise and if I'm honest with myself it will probably end up being ported and polished.
    *** FOR SALE ***
    Aug 2008
    NSW South Coast
    Yeah i'd say thats definately original. I'm leaning now towards thinking it may be from an early vt series 1, using some of the factory leftover vs parts???? Have you seen the Walker cross-ram ecotec manifold? I can get you some pics if you like, I live round the corner from the guy who made them. Good luck with it.
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    I've got this pic of it... If you have any others I'd love to see them! This manifold is sexy! The only issue I have with it, is it looks as though it would block access to the rocker covers when you need to remove them. I'd love to see one installed on a car
    *** FOR SALE ***
  15. #15
    CoMrAdE MaRx23's Avatar
    CoMrAdE MaRx23 is offline CoMrAdE MaRx23 CoMrAdE MaRx23 Executive
    VS Executive 1995
    Jun 2009
    Aug 2008
    NSW South Coast
    I'll see if Anthony has any more pics of it for you. And yes the plenum chambers on this manifold almost sit on the rocker covers. This needed to be done so that it could be fitted under a standard bonnet without the need for a bulge. The alternator also needs to be relocated. Im still trying to track down a pic of one installed too, but im pretty sure he only ever sold around three of them, so they're a bit rare unfortunately.
+ Reply to Thread
  1. Models with reverse sensors as standard
    By VicCop in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-04-2009, 07:17 PM
  2. Ecotec and L67 loom swapping?
    By VSSECO in forum V6 Development And Modification
    Last Post: 18-10-2008, 08:19 PM
  3. C.O.M.E racing manifold plenum for ecotec
    By djeyecon in forum V6 Development And Modification
    Last Post: 11-05-2008, 11:54 PM
  4. Plenum Problems (ecotec)
    By andyman in forum General
    Last Post: 26-03-2007, 04:41 PM
  5. WTB: Ecotec plenum chamber (VS)
    By 2_SeeK_U in forum Swap / Wanted to Buy / Trade
    Last Post: 28-11-2005, 04:38 PM
