Hello Commodore Knowledge.
I am fitting an intercooler to my V6 and am having problems with reverse plenum It is a VR v6 with a side mount powerdyne CAPA kit, with a custom made inlet manifold to reverse intake. The manifold is just a standard vr with the top chopped off and a ecotec top welded to it. It runs the ecotec T/B which i have extened both sensor plugs for the throttle body.
At the moment it is running N/A so i can fan out the bugs.
So my problem is that the car will drive fine under acceleration but if you try to maintain a constant speed, the engine revs die and only come back on once more throttle is applied.
I have checked all wiring, replace TPS and idle step motor and many other things . The only thing that i can think of is the ecotec throttle body is causeing the drama.
Any suggestions welcome cause i am out of ideas
All GO
have you checked for any vacuum leaks?
Yes all lines checked with vacum guage, and some replaced gonig 4 another test drive now.
All GO
the best thing would be to hook up a laptop and datalog with software like EFIlive. software is free for trial purposes and a ALDL cable is fairly easy to make or you could possibly buy one from someone on the forum
Body by Holden, Soul by Brock
the Legend will live forever
Yeah mate plan to do a bit of a write up once i have cooler pipes done, Will post up heaps of pics and details.
All GO
