markER717
Un-Donated Member
- Jun 7, 2009
- 472
- 1
- 0
- Location
- Geelong, Victoria
- 1990 3.8L VN Calais S1
Hey guys,
I have been researching for the past couple of weeks whether or not this is doable, and so far I've found out, that yes, you can mount a S2 intake on a S1, yes, you can mount the Buick's Intake Manifold rotated 180 degrees, but what I'd really like to know is: Can you reverse mount a VN S2 intake on a VN S1 motor? My reason for doing this is so that I can keep the thermostat housing at the back as I believe it looks far cleaner and wiring modification/coolant plumbing would be at a minimum.
Also another question on the fuel rails, is it possible to mount them as such, so the pipe that joins the two rails, is still at the front with the manifold mounted in reverse? would this require a custom pipe?
Any help is greatly appreciated.
Cheers,
markER717
Cheers,
markER717
