Just wanting too double check this can be done before i throw $200 dollars down the drain
its all explained in the auction item
Holden Commodore VR V6 auto ECU converted to T5 +wiring (eBay item 270694889605 end time 30-Jan-11 03:29:00 AEDST) : Cars, Bikes, Boats
97 WRX AWD
Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
Turbosmart dual stage boost controller
IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
BP98 safe tune @ 171.8awkw
its just an auto ecu with the error codes turned off and a few bits of wire to get the speedo to go
used that kit when i did the 5 Speed conversion on my VR worked a treat. Had no problems runs awesome
So you dont think i should waste my money delco. because ive heard it works for people.
97 WRX AWD
What he's saying is its not that different from the current ECU you already have.. there's some diagrams here to show how to get the speedo to work (in how-to section) and all you need is someone with a chip burner (few guys on here) to do a tune with no auto error codes, i think that seller on ebay could even do the tune for you if you send him a spare memcal.. would save you buying a whole ECU.
Power is measured in DECIBEL
