Page 2 of 32 FirstFirst 12345612 ... LastLast
Results 26 to 50 of 800
Like Tree77Likes
Thread: ** Rebuilding a Stroked/Turbo VT Ecotec **
  1. #26
    VT
    Apr 2005
    QLD
    Good thread.
    When is it off to the machine shop?
    Get some pics of it going through the motions there if you can
  2. #27
    holden_4aw_lyfe's Avatar
    holden_4aw_lyfe is offline Tsu Tsu Tsu Tsu
    Twin Turbo Stroked 4.2LT VT Berlina
    Feb 2009
    Thanks VT-565. I took everything to the machinists this weekend, and was told that I'd have it back in 3 weeks time bottom end done. So ill have to do the rest. I'll post pics when I get the cam and heads, and when I get the block back so I can photograph everything that goes on and post it here
    Don't Knock My Turbo Lag, It Gives Your V8 A Chance
  3. #28
    Feb 2009
    Will the bosch m90 36lb injectors fit in the ecotec?
  4. #29
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    youre better off buying 60lb seimens deka injectors straight off the bat saves upgrading injectors time and time again when they keep maxing out
  5. #30
    Feb 2009
    Isn't 60lb a bit too overkill? I got told u can buy too big of an injector??
  6. #31
    в∞ѕтεכ √&
    Jul 2008
    NZ
    when you max out 39lb while tuning on 8psi then buy 42lb and max them out and then buy 60lbers its a lot of time and money wasted i put 60's in every build now for that reason
  7. #32
    Feb 2009
    Fair point. 60 it is. I'll buy them today. Thanks delcowizzid
  8. #33
    VS ute
    Nov 2008
    that the reason i baught 80's! and for the same price as 60's why wouldnt you go 80's
  9. #34
    Feb 2009
    because down low they dont have enough pressure and they dribble and not spray?
  10. #35
    в∞ѕтεכ √&
    Jul 2008
    NZ
    they have the same pressure weather at idle or at revs so its no issue and the delco ecu is capable of missing every second fuel pulse and doubling the opening time to make huge injectors idle and cruise like stock ones
  11. #36
    Feb 2009
    providing they tune It that way?
  12. #37
    Feb 2009
    Picked up the Cam and Lifters today, so exciting THANKS MACE!
  13. #38
    Feb 2009
    **Update**
    Just got heads, vavle springs and oil pump. Heads look neat, and being aluminium they are pretty light.
  14. #39
    5.0L VS EXECUTIVE
    Mar 2010
    Geez man i wish my wallet was half as fat as yours WAS.......
    That is a nice way to blow around 5 grand
    96 VS ute, L36 Auto.
    Pacies, 2" catback, 18" RJR Shaddows
    No more V8'S, GT35 TO GO ON SOON
  15. #40
    в∞ѕтεכ √&
    Jul 2008
    NZ
    now you just need to port them heads and flow test the suckers and cc the chambers to suit boost
  16. #41
    Feb 2009
    5 grand??? i wish it was 5 grand...so far ive spent 12...still got another 2-3k left then 7k+ for turbos.....:S
    the heads are already ported 56cc chambers increase compression, 148cc intake runners, 58cc exhaust, 1.96 intake 1.57 exhaust valves
    reckon i should go more?
  17. #42
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the heads will be out the box un-touched ide be getting them flow tested and probably open the chambers up to unshroud the valves and lower comp back close to stock ratio or lower depending on what pistons you ended up with .shame they dont have flow figures for them could flow worse than stock :P or the same which would be pointless just bolting them on.they are bound to need port matching to the inlet manifold anyway
  18. #43
    Feb 2009
    good point...ill get it all measured and played with to match thanks delcowizzid
  19. #44
    Adam_88's Avatar
    Adam_88 is offline soon to be boosted
    red VY Ute
    Nov 2008
    canberra
    what power are you chaseing im also building a 4.2 stroker but im after 550-600hp
  20. #45
    VY SII HBD Calais L67
    Dec 2006
    Quote Originally Posted by delcowizzid View Post
    Those heads are a complete re design of the ecotec head. They aren't just an aluminum cast of a stock ecotec head. Valve angles are altered, coolant passages are equalised and revised for routing along with chamber design being vastly improved. Valves are already de shrouded in the alloy casting. Most important thing on these heads is that the exhaust short turn radius is lengthened to overcome the biggest flaw of the ecotec head.
    VYII Calais L67
  21. #46
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yes i know they arnt ecotec castings LOL just depends what version heads they are if they are early ZZP leftovers ide bin them LOL took them so many goes to get them anywhere near good wrong cooling passages too big and too small passages one casting didnt even have them at all LOL even mace wont post flow figures for them costs #### all to get a head flow tested why is there no figures??i wouldnt even look at them untill i had seen some sort of results/tests etc.set of hand ported cast iron heads will outflow these alloys as they come out the box
  22. #47
    Adam_88's Avatar
    red VY Ute
    Nov 2008
    canberra
    a mate of mine had some mace heads that were flowed and ended up throwing them in the bin he made more with the standard heads!!!
  23. #48
    Mar 2008
    Quote Originally Posted by Adam_88 View Post
    We've every only delivered 7 pair of heads (inc 4 sets of alloy heads), and not a single set to Canberra. I would be incredibly surprised if they were our heads. If you mate has an invoice number and genuinely not happy the heads I'll happy refund his money in full. The last set of cast iron heads we sent up to a customer was when we first released them on the forum back in 09.
    V6 Peformance Parts
    We haven't been heavily advertising ported factory heads as the initial company that helped us out with them, was not consistent. Needless to say I still have two sets of his heads here which have been stilling on the shelf for over a year now...
    In saying this though this is going to change with company we're working with, plus our own CNC ported heads
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
  24. #49
    Mar 2008
    DW,
    Have you seen the heads in person to make an accurate judgment? In regards to flow benchs, they vary worse then dyno's, so posting up flow bench figures using a state of the art SuperFlow bench, is definately going to different figures then ol mate running seven domestic vacuum clears, with just a manometer and everything else in between. Comparative testing on the SAME flow bench (or reputable ones), with accurate temperature/weather compensation etc is the only way to get meaningful results.
    From feedback we've received from customers, with actual product experience and in the hands of professional head porters, these alloy heads flow about as well as a set of good factory ported heads out of the box. Where they really shine though is when they're ported, reaching flow far greater then the "best" factory ported head, with the simple fact that they have much more meat to play with, coupled with revised chamber and runner geometry off the bat
    MaceEngineering
  25. #50
    в∞ѕтεכ √&
    Jul 2008
    NZ
    no i have not seen these in person but i have a network of tuners and engine builders around the world who have been involved in trailing these and have reverted back to ported cast iron heads i have also seen how easily damaged they are in boosted situations with not enough headstuds to hold them down as well as the ones with extra holes for more studs.there was a time i was searching high and low for alloy heads now i wouldnt even dream of running a set unless i got them for free to try you blow a head gasket they need welding and surfacing do that a few times they are only good for scrap.surely you must have some flow figures for a ballpark flow value i have flow figures for all stock holden buick and ecotec heads and ported flow figures from a reputable flow bench to compare them too
  1. Rebuilding Ecotec
    By Weapon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2010, 09:51 PM
  2. ecotec turbo.
    By braundog in forum V6 Development And Modification
    Last Post: 11-02-2010, 10:06 PM
  3. [VIC] Ecotec Turbo Kit
    By VSEXEC in forum Parts And Other Items For Sale
    Last Post: 10-08-2009, 07:14 PM
  4. rebuilding v6 buick or ecotec. performance
    By marshcory in forum V6 Development And Modification
    Last Post: 22-05-2009, 08:52 AM
  5. twin turbo ecotec, turbo selection?
    By jenkos_vl in forum V6 Development And Modification
    Last Post: 08-11-2005, 12:03 PM
