Comparison..
isnt that what dyno and flow benches are for?
I havent really followed the whole ecotec craze but i Have to agree with delcowizard. How hard is it to compare these heads to stock its not like stock heads are unicorns.
Everyone i know PERSONALLY who has heads ported gets a sheet thats show before and after figures.
In the end that the whole point to the process
Originally Posted by Smidy
To compare before and after results on the same car or same set of heads on the same dyno or flow bench yes, I 100% agree. To test two different cars/or heads on the same machine ideally, over a short period of time, would give an accurate result if product A is better then product B or visa versa.
To compare between different dyno/flow benches to two different cars/heads and treating them as accurate results then that's asking for trouble. Excellent example of this would be the power figures a car on a dyno dynamics dyno would make compared to a mainline, noticeable difference there even when the same car is tested! As useless as these results are, things get worse when your trying to compare the same component type, modded differently, on two different machines.
As for comparative testing of these heads compared to stock that's not a problem, in fact would be the best way for people to control or calibrate a test if they wanted compare tests done on different machines etc. The results then could be scaled on excel for a fairly accurate visual comparison. How many people do you think would have done this though?
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
How much do you think a set of quality race ported factory heads, new valves, springs, retainers, collets, new guides etc. costs in Australia? Not "mates rates" prices?
You've never seen these alloy heads up close yet you're quoting on how much they'd cost to port? Even at $100 an hour they definitely don't need 14 hours of work to blow a set of factory heads out of the water, hence the premium. At this level of build "bang for buck" start wearing thin there is no way around it.
MaceEngineering
seems maybe they are not worth porting ZZP inform me theres only about 2-5% extra flow from porting as they allready have the short turn radius maximized out the box and the seats are allready blended into the bowls etc
I don't agree with that statement complete. Yes they are an excellent head out of the box, however if you're game to port manifolds along with the head that quoted figure will easily be surpassed, honestly this is me speculating based on having seen the heads in person and experience with other tests in the past. Having taken to them with a set of calipers you can, proportionally, increase the overall geometry of the ports however this would require larger intake and exhaust runners
MaceEngineering
Despite aluminium having a lower modulus of elasticity compared to cast iron, the alloy heads have more meat resulting in a positive impact on moment of area in both planes. If I was a betting man, subject to the same load the alloy heads would probably be stiffer! As for repairing alloy heads, given the quality of the casting and someone who knows how to weld cast alloy properly, I can't see it being a problem with these heads with the appropriate filler wire and treatment etc. As for welding up factory cast iron heads, which often crack between valves, I'd give it a miss even with a welder who knows what they're doing, unless it was a Model T Ford cylinder head which are about as common as unicorns![]()
MaceEngineering
14 bolt turbo alloy head, arp studded with cometec gasket after lifting at 22psi messy stuff![]()
Adam_88,
id be VERY impressed if i got around 550hp. I don't know what im expecting yet, im just doing things right, taking my time with the build, and getting the max potential out of the engine as much as i can. Remembering there's still 2 turbos to whack on after it's done![]()
Don't Knock My Turbo Lag, It Gives Your V8 A Chance
Adam_88,
Keep me posted with any problems you have, and what youve done to make your build betterLet me know how power figures go
If you are blowing head gaskets on these things, nothing will save you. They should be run with MLS and I wouldn't consider anything less than the best for a good set up. Only as good as the next weakest link.
424rwhp, stock L67 bottom end, XPZ cam and alloy heads. 11.49seconds. YouTube - 11.49 ET @ 120 mph whippled v6
Not testamanet to the heads but no issues were experienced and the car was running nearly 18psi of Whippled 2.4L boost
VYII Calais L67
Ill say it again..... Theres stuff all to be gained from port matching the stock head. The Stock head has a port that is too large, as it was designed on an angle cut for an almost vertical plenum leg on the bunch of bananas stlye manifolds in the USA.
So the port is too big for the australian runner.
In the stock heads, quite a bit of gain can be achieved from cleaning up the back of the valve and bowl area though.
So if the alloy ehad already has that, for $1400 a set, well that sounds bloody interesting. especially as alloy conducts heat much better, and is not prone to cast irons thermal 'deposition' problems which can give localised hot spots.
Now if someone cumes up with an inlet trumpet manifold that has a runner thats relatively straight and around 20" long...well then we can match the trumpet to the port in the alloy head and give a slow concentric reduction in runner volume all the way from bell mouth to bowl. Perferct world....
double that $1400 for a set LOL
im still going to port match the heads to the manifold, and the ports in the heads are a bit rough ill use the porting tool and fix them up a little bit but besides that they look amazing
Adam_88;
what problems? im planning on running around 20- 23psi safetly. My bottom end is good for 30-32psi aswell. Are you putting it together as we speak?
nah it's getting machined and concreted at the moment
click here to view my ride http://forums.justcommodores.com.au/...02-vy-ute.html
what injectors you planning on running?
in my VR i actually opened up the heads to the same size as the gasket, and you are right, the opening in the head was HUUUUGE compared to the mani, so i went to town on the mani. opened it up all the way up the runner. i noticed a big lack of low down oomph, but above 3500 (where my cam was anyway)(and ill add, turbo cam/no overlap) crazy pickup all the way to a 6700 rev limit. and that was with a shitty HSV3800 tune and NO TURBO! there was no noticable flat spot until the rev limiter kicked in.
not fighting you, just adding my experience with porting and my result. =D
im not sure yet im gunna let my tuning bloke decide
yeah i think thats a good choice..went and saw my block, 3/4 of the way done. looks mint. Ill post pics soon!![]()
New photos,
Got all the top half of engine hand polished by my good friend Alan at Myrra Metal Polishingstill got the Alternator to go, and Thermostat Housing along with all Brackets/Bolts Ect. Let me know what you guys think
sorry about bad quality photos by the way...crappy camera
Personally I reckon it looks great..
thanks Moggy! theres still a HEAP to be polished, ill post more pics up when its done. Cheers mate!
I am looking forward to seeing photos of the finished product. hope it all goes well for you and yes I am a little envious. Hay what is concreting the block?
