its been racking my brain for days now... reckon its possible to convert a commodore v6 back to carb? i know it seems stupid and its something that wouldnt gain anything from doing it but still... i wonder if its doable. the buick v6 used to be carb anyway so im wondering if theres a spot in the block that used to be a hole for a distributor that could be machined out? the cam would have to be modified for a gear for a distributor obviously and all that.. big job. but doable?
what does everyone think?
Theres a manifold to suit
I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
oh madtheres one part accounted for...... but im still wonering about the ignition system??
that manifold wont fit and you wont find one that does LOL have to custom make one out of a stocker manifold and a carb plate made of alloy welded on top like the speedway guys do
Why would you?
dear me, why the fark?
It would sound better than EFI but that's about all it would have going for it.
With the Buick it is possible but with the Ecotec I have never heard or seen anything about it.
why the fark indeed.... im not gonna do it im just trying to get my head around if its possible.... has it been done?
Well for instance if you want to put the V6 into a bush buggy?
EFI doesn't like hard knocks. Sensors flip the birdy.
I profer carbs over EFI for modifying anyway. They can work just as well.
seen it done to a vp ute.
Could you perhaps use a remapped ecu, just tell it to ignore the fuel mixture tables? So long as the crank angle sensor is still on the engine it should know how fast its spinning and where in its rotation its up to, right?
If after installing your new stereo all you can hear is rattling, you need a louder stereo.
Triple down draught Webers!!![]()
Anything is possible.. just not "bolt-on" for many good reasons.
#1 - It comes factory EFI...
#2 - EFI is good and easily tuned.
#3 - A dizzy?why ditch the direct fire ignition? it's worlds better than a dizzy. GM spent moonbeams developing DFI. It's more accurate and carries alot more current - better spark, better bang!
#4 - why not just get a Chev V6 or a dirty old 308 they carb and dizzy standard
Having made those points clear, if you did carb but stayed with the Delco to control the DFI, the Fuel tables can stay, as "fuel" in the ecu wouldn't be used. Just leave the injector wires unconnected.
You would have to use the MAP sensor connected into the manifold for load reference (tapped into all six runners for Webers) and a TPS on a Carbs throttle shaft so ecu knows throttle position (idle, back off & WOT)..
Change fuel pump to low pressure/high flow or reduce pressure of stock efi pump with a regulator.
Jet and tune to suit!![]()
"Life's a dare, push yourself, F#@k it you might like it. Live on the edge. It could all stop tomorrow"
- Jimmy Barnes twitter March 2011
3.8T Wagon
wont fit buick either they are all different thats for old buick not any of the engines in a commodore
Well there u go then....
