Results 1 to 4 of 4
Thread: vs gearbox sliping in 3rd when hot
    STL17's Avatar
    STL17 is offline Whipit
    VS STATO , VP EX COP
    Aug 2009
    townsville
    Default vs gearbox sliping in 3rd when hot
    hey lads i have a slight problem i have a vs ecotec in my vn with a vs box behind it and last night i was at the drags and after the 4th run my box lost 3rd gear i thought for sure i had blown it but this morning i took it for a lash and i had all gears again so i am putting it down to heat maybe. i have a trans cooler and its going through the radiator to the cooler and i also have a shiftkits australia shift kit [electronic] is there anything else i can put in it to stop it from slipiing in 3rd i see you can get 2nd gear servo's for the auto and it helps 3rd gear shifts aswell as 2nd should i get one of them aswell as a transgo stage 2 shift kit
    its only done it since i put my 3.73 diff gears in
    tuning done by THE1 A+++++ tuner
    And powering it by MACE
    Build it to handle the MANG
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Check your tranny fluid levels, should be spot on with it. Also give the trans a service if you haven't recently.
    Check the state of your trans fluid when you do the service. Dark brown with a burnt smell is bad news. Could be a failing 3-4 clutch pack, a faulty valve, worn governor gear, or a multitude of other things but do those couple of things first and see how you go.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    STL17's Avatar
    Aug 2009
    townsville
    Yeh i done a service last week and the oil was brown but there was a small amount of metal colour in it
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    More than likely a failing 3-4 clutch pack. You can probably drive it around carefully for a little while before it completely gives out but I'd take it in to a trans shop as soon as you can. Get them to diagnose it properly and go from there. You'll probably be looking at a rebuild or you can try and pick up another second hand unit to swap in.
    1. 1990 VN Exec V6
  1. VS11 auto trans flaring and sliping
    By timmysvs11 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2010, 11:35 AM
  2. WTF!!! Trany sliping n not going in2 gear
    By maco_butterfly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2008, 02:44 PM
  3. sliping
    By vq_statss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 09:47 AM
  4. auto sliping
    By Insanesinner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2006, 10:38 PM
  5. Sliping Back Diff.... :(
    By Azza- in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2004, 10:03 PM
