Just wondering what injector sizes people are using on there blown or turboed ecotech and fuel pumps
i dont really want to go bigger then i need to and want to keep the fuel pump an intank one, im keen to get it right the first time
Mine is starting to lean out top end
14PSI XB1a Powerdyne
1into 6 FMU
Standard Injectors and pump
Anything worth shooting is worth shooting twice. Ammo is cheap. Life is expensive.
255lph Walbro fuel pump, 80lb injectors (~880cc) along with alky injection My 660cc injectors didn't hold up with the power
584whp 551 wtq, front wheel drive
3.8l turbo
So your using the standard fuel pump and injectors from the 3.8 ecotec?
what about standard tune?
Why im asking is i have a powerdyne supercharger that i want to put on , but i need some super 6 injectors .
But if your running then on the standard ones, i should be fine then haha
425cc injectors and 255lph in tank pump, 9psi on a 4 litre engine, AFR's between 11.5:1 and 10.0:1 @ WOT
I had a tune with the auto in it now its back to manual on a standard tune with it also runs well but def best off switching injectors now before tune
it will run if you have a FMU hooked up i use 1 to 6 ratio, it will work well with a BD-11 on standard fuel system
cheers thats a start bit more hp then i am aiming for im more going for 400HP at the wheels sounds the go tho
