Results 1 to 5 of 5
Thread: manifold spacer or cai
    Vs Commodore and ve sv6 2011
    Sep 2010
    sydeny
    Default manifold spacer or cai
    hey guys just wondering which would best best to get first CAI or 25mm manifold spacer because only enough for one which would i get most power out of
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    if you do your own tunes CAI might help get a bit more timing, if you havn't got extractors get a set of them put on instead of either of those 2. Oh and prob should have posted in the VS forums not here.
    vt s pack
    Oct 2010
    brisbane
    go to cai first and then work back.
    btw this is the right forum?? its asking about power for his 6 banger, not things for jst vs..
    Sep 2010
    sydeny
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    i thought this forum was for if you are developing or modifying something, which the op isn't doing, he's just wanting to fit aftermarket parts. My bad if this isn't right, to the op get a holden super 6 CAI if you can find one cheap, even at the wreckers, if you have money to burn get a mace fully enclosed type CAI.
  1. manifold spacer on ecotec -- WOW
    By VS 666 in forum Mace Engineering
    Last Post: 02-02-2012, 03:30 PM
  2. Manifold Spacer Fitting. Does it fit VY S2 Ecotecs?
    By MagiTEK in forum Mace Engineering
    Last Post: 12-01-2011, 10:04 AM
  3. Reveiews - Manifold spacer, TB and Chip
    By Tsunamix in forum Mace Engineering
    Last Post: 24-05-2010, 10:34 PM
  4. Mace VZ Alloytec manifold spacer?
    By HannibalK1ng in forum Mace Engineering
    Last Post: 03-03-2010, 01:28 PM
  5. throttle to manifold spacer = power?
    By matty8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2009, 04:12 PM
