Results 1 to 14 of 14
Thread: Who knows L32 conrod direction/orientation?
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Default Who knows L32 conrod direction/orientation?
    As the title says.
    Im getting many different answers as to which way the dots face.
    Anyone know for sure?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    which dots are these are they on the big end of the rod?
    Maybe a pic been awhile since i built a six almost 2 years now.
    Edit i'm going to hazard a guess and say that the dots are for rod/ cap matching and being balanced it wont affect as long as piston orientation is correct. These are stock rods yeah? (may sound stupid as title say l32)
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Sep 2005
    Quote Originally Posted by Pub247 View Post
    Yeah theres a dot just above the big end.
    The rods are out of an L32 supercharged from the states. They're forged steel.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Ah well i never worked with those rods i've only done local motors i assume theyre the same as l67 then? is the weight the same as original rods? thats more from curiosity.
    I honestly wracked my brain i cant cant see how flipping them around would change anything. Theyre symetrical and should weight the same on every axis being balanced.
    Sep 2005
    Theyre stronger than L67. L36 ecotec are cast iron, L67 are cast steel but L32 are forged steel and quite beefier than L67. So yeah they would be alot heavier, my balancer guy gave me the readout and it shows 450 grams heavier lol.
    Ive pulled out a piston tonight and i'll check for any offset tomorrow at work. If theres none then it wont matter.
    The only other thing im worried about is the bearing tangs. What if they are designed to take load only in 1 direction and if its the wrong direction then the bearing may spin...
    Scary stuff when you've spent so much on the rest of the motor lol.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Can you post a pic up pleaseso i can have a good look at one.
    EDIT does one side have a chamfer? or radius
    Sep 2005
    Yeah has a bigger chamfer to one side. Thats the original way i set them all up. Big chamfer to the nearest main bearing.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yeah that's the way i'd do it bigger chamfer towards main.
    Are all rods same by that i mean the bigger chamfer is on the same side rods as all the dots are
    Whats the numbers on the side? are they all same ?
    I hope the balancer took the extra weight into consideration. Are you using the stock crank? (kinda sounds stupid now i reread the above posts.)
    I dont think bearing tang is going to much of an issue aslong as the cap is around the right way. Though i do know that some motors have them pointing to exhaust side or on the "outside" of the motor.
    Sep 2005
    Numbers are all different but are all on the same side.
    Stock crank.
    Yes its had a full engine balance so the rods and pistons are weighted, ground so they weigh the same then balanced with the crank as a rotating assembly with the balancer and flex plate.
    He balanced with the flex plate and balancer on the crank and added weight to the crank to compensate. So if i ever have to change the balancer or flex plate then i just change them without balancing again.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    ah ok cool balancing sounds all good then.
    With the bigger chamfer towards the main where does that put the numbers on the outside? (I assume the numbers were already there and the machinist didnt add them.)
    Sep 2005
    The numbers are from factory. Half will face one side and half the other.
    Sep 2005
    Ok the other day i sent this e-mail to Intense racing.
    ''Hi,
    Im building my L36 twinturbo.
    Im running your L32 rods and your coated Diamond Racing pistons 8.0:1.
    On assembly im finding the small ends of the rods are slightly out of centre on the wrist pin. This causes the small end of the rod to slightly rub one side of the radius inside the piston.
    I don’t quite understand when you say bearing tang toward the pan rail as there are 2 sides to the pan rail.
    I have installed them with the bigger chamfers of the big end towards the nearest main bearing. Is this right?''
    I got this response.
    ''There should be no contact of the piston to the rod. The rods all have a dot on the beam above the bearing on one side. That dot needs to be facing the front (pulley side) of the engine on all 6 rods. Also make sure the pistons are all facing the right way, they each have the letter “F” stamped on them. The “F” should face the Front of the engine as well.''
    I then sent this back.
    ''Thanks for the reply Chris.
    Why does it say ‘’Bearing tangs toward pan rail’’ at the bottom of the page? INTENSE-Racing.com: L32 Connecting Rod
    If that is the case then you will have half the dots facing forwards and half rearwards.
    I just wish I could get a straight answer from someone lol. I can’t find a definite answer anywhere.''
    I got this response today.
    ''I have no idea why the website says that, or what it really means. It said that before I worked here, I am going to see if John will change it. Anyway, the dots definitely point towards the front.''
    I think im going to go dots face towards front lol.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    well there you go problem sorted If only engine manufacturers could agree to a standard.
    I know windsor v8 tangs are to pan rail and big block clevo are to camshaft side.
    Gotta be happy thats sorted.
    Sep 2005
    Yeah i do feel better lol.
  1. Vz v6 conrod bolts replacement
    By v6rick in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-10-2010, 02:44 PM
  2. [SA] Wtb: 304 conrod
    By shy304 in forum Swap / Wanted to Buy / Trade
    Last Post: 28-09-2009, 11:50 PM
  3. VN S1 Conrod bearing size??
    By needwork2-4fillhabbit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-09-2009, 11:02 PM
  4. Amp mount position/orientation
    By Claymore in forum Car Audio
    Last Post: 10-02-2009, 09:26 PM
  5. conrod and main bearings
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-07-2008, 10:33 PM
