Results 1 to 6 of 6
Thread: any way to make a th700 work in a vs??? please help
    Dusty_vs is offline your resident mechanic
    97 vs excecutive sedan
    Jan 2010
    sydney nsw
    Default any way to make a th700 work in a vs??? please help
    is there any way at all to make a th700 work in a vs commodore? (keep in mind the vs auto runs the 4L60e from factory) im trying to work with what ive got.
    any help would be greatly appreciated
    VR Brolina 3.8 Turbo
    Aug 2008
    Wellington, New Zealand
    My vr came with a th700 in it. Delcowizzid was working on a way to make it fully functional but the th700 died so was replaced with a 4l60e anyway. The previous owner must have just bolted it in. Still had all gear's but the torque converter lock-up did not work. Odlly enough he's meant to be coming out today to remove said 4l60e and replace with another th700! but this time weve replaced the loom/ecu with a vn one.
    R.I.P dynoryder
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    to work at which trans you have, lift the bonnet and have a look down the passanger side of the trans tunnel. on the side of the trans there will be a fairly large sticker which should have a code on it. something like 7HDD
    you have a couple of options.
    1, fix what you have
    2. have the ecu tune modified to a manual configuration and modify the loom to suit T700 box
    3. fit a manual loom and ecu
    4. fit a VN ecu/loom as chrrr said above
    Body by Holden, Soul by Brock
    the Legend will live forever
    Jan 2010
    sydney nsw
    have you got wiring diagrams for both gearboxes so i can see if i can modify it?? the thing is i bought the car for 300 bucks from a chick that took it to a mechanic that fitted the th700 with no ecu or loom mods and it stopped 15 kms down the street... so the box is already in.. i just wanna see if i can make it work as it is....
    besides apparently the ecotec works well with a th700 behind it??
    VP Exec
    Jun 2005
    Stopped why?
    You may be better off to pull the TH700, sell it on and swap it for the correct replacement.
    If not, you will need to make provision for the throttle valve (TV) cable. This needs to be set up to reflect the torque output of the engine and if it's wrong the trans. will die pretty quickly, not to mention shift strangely. I would suggest reading some of the myriad of technical info. available on the web from vendors fitting TH700's in non-standard applications and look into adapting a VN-VR cable bracket and cam.
    The lock up TCC isn't a major concern. The trans will operate without it at a small cost in fuel consumption. It can be switched manually very easily, again there's plenty of info. around on how to do that. Setting up a speed activated switch to approximate the ECM switching isn't hard either (Jaycar/SC kit).
    Speaking of speed sensors, a power and earth to the Hall sensor on the TH700 will give an output on the signal wire. To feed that into the VS PCM (required for speedometer operation) the signal will need to be altered. There is a SC kit to do that also.
    The Creative Calibrations site has wiring diagrams.
    By the time you do all that you probably may as well have swapped the proper trans. in.
    Jan 2010
    sydney nsw
    thanks heaps for the input guys... ive managed to scratch around and find a 4l60e trans out if a vs to throw in it.... ive got the trans out of the car... the one that i took out has "4HDD" or something similar on it... what trans is this i was told its a th700??
    the one i got to put in it.. (not looking forward to putting it in lol ive got to lift the ****ing thing in by myself.. no jacks available) has "6HDD" on it.
  1. Can work make you take out peircings
    By Timmos in forum The Pub
    Last Post: 01-12-2010, 02:08 PM
  2. Th700
    By czerwonyVN in forum General
    Last Post: 14-02-2007, 02:17 PM
  3. w/t/b th700
    By mr vq in forum Swap / Wanted to Buy / Trade
    Last Post: 02-12-2005, 02:46 PM
  4. Bulletproof TH700
    By synchro66 in forum V8 Development and Modification
    Last Post: 26-08-2005, 02:22 PM
