Results 1 to 13 of 13
Thread: Springs Vy's
    Vy 2003 Acclaim
    Mar 2011
    bundaberg
    Default Springs Vy's
    Just a quick questian Will say lowerd springs from a commodore ute fit a sedan as a guy on ebay has them for sale they look identical to me?
    Vy 2003 Acclaim
    Mar 2011
    bundaberg
    Default Throttle body
    i have another questian i took my engine cover off my vy ecotec v6, then i unscrew the allenkey head bolts from the top of the throttle body removed the top cover an gasket rubber to find it is black as crude oil an just down right filithy,i have noticed ther a a number of 11 or 12mm head bolts zig zaging along from front to rear is that how i remove it to carby clean it ? thanks guys
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    #1, the springs may very well fit, but id say they would be different strengths and therefore would be firmer or softer and sit at a different height.... ect
    and #2, the lid just unbolts via the allen screws and then yes you can spray carbi cleaner into it. one suggestion tho, is that you pull the spark plugs or you will get compression lock from the fluid sitting in the head/valves. i learnt the hard way and nearly burnt out a starter motor. another suggestion would be just to undo the intake pipe (unplug the maf) and spray into the TB with the engine running and bring up the revs while spraying or it will stall.
    i did it that way to my wifes VX. cleaned up the plenum real nice.
    edit, just re read your post, if its real gungy and oily in your plenum perhaps its time to look at a rebuild? that mess is usually caused by a lack of compression creating blowby and thats what your PCV breathes. and that means your engine is also breathing it.
    VY SII HBD Calais L67
    Dec 2006
    Nah, ute and sedan springs are all different rates. No good
    VYII Calais L67
    Vy 2003 Acclaim
    Mar 2011
    bundaberg
    Ok well iam quite keen on removing it an cleaning it up properly,an its only done 115.000Kms dosent blow smoke i look after it, well i do my best but thanks heaps im going to clean it now,an ok i wont order the ute springs(things id do if i didnt have this site an u guys to get advice from.)
    Vy 2003 Acclaim
    Mar 2011
    bundaberg
    Vy 2003 Acclaim
    Mar 2011
    bundaberg
    Quote Originally Posted by TattoozNCars View Post
    hey well i have just finnished cleaning it i took the intake manifold an plenuim chamber off with out removing the fuel rack lol sneeky i think lol gunna go take it 4 a spin
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    also what about hsv V8 springs will they work in ym Vy accliam?
    front or rear? fronts again will fit, but V8 is heavier than a V6 so will sit higher in the front, rears would be the same between models.
    Vy 2003 Acclaim
    Mar 2011
    bundaberg
    Quote Originally Posted by klampy View Post
    I have superlow fronts already just chasing the rears but thanks mate,so i guess the rears will do fine then ? same just a tad stiffer,also i took the vy for a spin ,an i might say it is much more snappy, responsive thats for sure but im dropping a can full down its neck 2morrow so i can clean the internals a bit And i put a mod chip in my vy an it does f!@# all so i ripped it out Hunk Of S!@# Dont buy 1. Cheers guys.
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    what sort of "mod chip" did you get? was it a memcal or one of those resistor things that piggybacks a sensor?
    Vy 2003 Acclaim
    Mar 2011
    bundaberg
    i got +15hp high preformance chip that plugs into the IAT sensor advances the timing by 2 deg,apparently (cough) B.S! live and learn
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    ha. sorry . they do work. but! its definately cheating. all they do is trick the ECM into thinking its getting something its not. so dumps more fuel and advances the timing. i had one in my VN, but i had big pipes, bit TB, port work, a fuel pressure reg ect, so the little resistor helped by advancing my timing and pushing more fuel. so for me, it worked well.
    Vy 2003 Acclaim
    Mar 2011
    bundaberg
    Yea i dont have the cia yet or the extractors,plus it was a ebay chip from the Uk Plus i dont think its really worth it i saw dyno data on a car with it in an same car without,lost 6kw with it in ? but like u said diffrent strokes for diffrent folks.lol
  1. Are the VY's much different to drive than a VX?
    By muso in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-12-2011, 01:13 PM
  2. VY's Radiator into VX?
    By ahmedomnnea in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2010, 03:12 PM
  3. [Ecotec] the vy's V6 is the camaro's V6?
    By SMG_07 in forum V6 Development And Modification
    Last Post: 12-02-2010, 11:14 AM
  4. vy's air problems
    By qector in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2007, 07:56 AM
  5. Learning VY's
    By fxcustoms in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2006, 04:20 AM
