Just interested in peoples opinions of these parts. Am considering purchasing a 25mm manifold and 12mm plenum spacer and would like to know peoples experiences. any dyno graphs would be appreciated.
BTW currently running 1.9:1 high ratio rockers, 69mm TB, pacemaker extractors, 2.5" cat back, high flow lukey panel filter.
Would this be the best next set? am not interested in forced induction or cam.
I personally didnt notice the gain but dam the insulator saved my ass from my fuel rails hitting the plenum awesome idea![]()
will help ya ecotec off the line thats were they suffer
tuning done by THE1 A+++++ tuner
And powering it by MACE
Build it to handle the MANG
yep, i fitted my spacers when i first got my car, and noticed a lot low down....i reccommend them any day![]()
Don't Knock My Turbo Lag, It Gives Your V8 A Chance
i reccomend that set up as well i had the 25mm intake spacer and 12mm plenum spacer and i noticed the improvement with the 69mm throttle body
I heard that you can loose some low end power when you fit the plenum space... Can anyone confirm this???
i was told by Mace that the 12mm plenum spacer would complement my current mod's and can expect roughly 5% gains in low down tourque. i found the boys at mace extremely helpful shoot them and email and they will answer any of your questions.
What mods do you have mate? I just remember reading somewhere on here that having the plenum spacer (not the intake insulator) on an otherwise stock engine (no internal engine mods) can actually be of a detriment :S Maybe it could have been if it was coupled with a bigger TB, not sure?
current mods are listed at the start of this thread as of a couple hours ago have ordered 24mm manifold and 12m plenum spacer also. With the current mods on dyno dynamics dyno am making 195rwhp.
Oh sorry man didn't realise you were the OP otherwise wouldn't have asked what mods you had haha
Definitely post back with results mate, should be pretty interesting to see because if it does fix the low end torque issue with the ecotec then I'll definitely be jumping on board as it's definitely the biggest pitfall I have with the engine. I currently only have a Lukey catback at the moment but my pacemakers arrived yesterday so should put them on this weekend hopefully![]()
High ratio rockers and improved air intake should be high on the list also if you are looking for "significant" bolt-on power gains.
Or if you want to get really carried away there is always RAPTOR.
Yea won't be going down the path of rockers that's for sure, can't be assed wasting too much money on it as the "significant"gains aren't significant enough to be justified haha...
Basically just want it to run as efficiently as possible...
