Page 1 of 3 123 LastLast
Results 1 to 25 of 62
Like Tree7Likes
Thread: Help stuck at 230kw only $2700 left in budget
    Blown VS V6 Wag
    Jun 2005
    East Side Syd
    Default Help stuck at 230kw only $2700 left in budget
    Ok I'm putting it out there to see what you guys can come up with.
    I have $2700 left to spend on her and have a few options.
    I know what direction I'm thinking but would like a couple opinions.
    Here is where I'm at.
    4.2 come bottom end 8.2:1 comp.
    Smallish cam.
    Stock heads with heavy springs.
    Pacemakers + System.
    Ported maf and tb.
    Mildly ported manifold.
    Mildly ported m90 2.8" pulley over driven crank. (11psi @2000-5600rpm)
    240kw @ 5000rpm
    460nm @ 3300rpm
    Running gear is.
    Th700 St2 2400 stall
    3.45 lsd. with over sized rolling diam tyres = 3.23:1
    Will need retune regardless of what I do so lets call it $1500 budget, can be stretched a bit.
    Problems are little M90 running very hot and cam too small.
    Solution are....
    #1. Bigger cam + port heads $1800 ish +9hrs
    #2. Bigger cam + IC $2100 ish +7hrs
    #3. Hi ratio rockers + port heads $1600 ish +6hrs
    #4. Hi ratio rockers + IC $1800 ish +5hrs
    So Power+reliability V work+cost?
    Opinions please.
    D22 St-r Navara
    Dec 2010
    perth
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    intercooling is your best option. either W2A or A2A. seeing as your going for a full tune anyway i'd recommend A2A as it's more efficient and then you can run a much smaller pulley then you have on now.
    also use a 82 degree thermostat and have the thermo fan on/off temps reset to suit
    Body by Holden, Soul by Brock
    the Legend will live forever
    Blown VS V6 Wag
    Jun 2005
    East Side Syd
    Thanks for your input Immortality.
    Don't want to mod the bonnet so can only fit a 25mm IC under M90 so options are Yella's or Mace's small ICs, which they say drop temps around 30 degs c.
    Also can't get much more puff out of little blower I would love to toss on a tvs 1900 but thats another $2k on top.
    Already have Davis Craig Elec water pump and adjusted thermo to suit slightly lower running temps,
    and all the other little bits like copper plugs, Walbro, CAI, so on.
    P.S Because of the small cam and hot discharge temps I have a good whack of retard, so what I'm after is the mods I'll get the most timing out of.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    $1700 Gt35/40 turbo
    $1000 turbo mainfolds
    problem solvered
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Intercooler for sure - you'll pick up a heap of torque.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Adam_88's Avatar
    Adam_88 is offline soon to be boosted
    red VY Ute
    Nov 2008
    canberra
    Quote Originally Posted by Pub247 View Post
    $1700 Gt35/40 turbo
    problem solvered
    plus 1000 in fittings,piping and plumbing
    Adam_88's Avatar
    red VY Ute
    Nov 2008
    canberra
    Quote Originally Posted by Zeussy View Post
    Two of the big ones. Just tell Harry you need them by tonight...
    cheep to $500 for a wet kit
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by Adam_88 View Post
    well he wont need all his old charger shit sell that theres your money for it
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    Mar 2008
    Quote Originally Posted by ToMMMaY View Post
    go turbo dude thats where the numbers/power is at
    Yeah, tear all that supercharger stuff off and start again. You should be able to do that for under $2000, right?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    If your doing most of the work yourself, there is no reason you can't go bigger cam and intercooled.
    EDIT: MACE even have thier cams on sale, you know you want too.
    Ronald Reagan (1986)
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    To be serious here. If your gone down the s/c root and you seem to spent a lot money on it and want to stick to it.
    What most people dont understand with charger and turbos is the efficiency maps. All your older eaton are only meant to do 13,500rpm at their max efficiency. these people with 19psi pullies are way over-spinning them and the end result is 19psi of heat.
    As said there's 2 ways to go here either cool down your intake charge or buy a bigger/better supercharger like a whipple which is more efficiencent. In your case and budget cooling will probably be the best choice and throw in a set or roller rockers (proper ones) that wont push you lift to high.
    A2A cooling is going to be cheaper W2A is better IF done right. With your budget go the A2A.
    These mods should net you a decent gain for your budget and you need to find some mates with good mechanical knowledge and decent welding skills you'll be able to get it done with rockers or cam within your budget.
    And best bit of advice your going to get is power figures dont mean shit. You have a genuine 12sec car there id say if best case scenario.
    Theres people with strokers and centrifugal chargers that your car should make lunch of as it is
  15. #15
    Blown VS V6 Wag
    Jun 2005
    East Side Syd
    She is pretty quick heaps of torque from 1800rpm I just know that there is another 30-50hp sitting in there restricted by heat and lift.
    If i can drop temps by 30 odd degrees and grab another 25thou of lift bump the curve a little higher then hopefully they will show up.
    So any one got some good second hand 1.7 or 1.8 lifters? (Rockers thanks!)
  16. #16
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by Lazin View Post
    So any one got some good second hand 1.7 or 1.8 rockers?
    i'll fix your post for you
  17. #17
    Apr 2006
    Auckland NZ
    the MACE A2A should fit under a standard bonnet. better then W2A but needs tuning. then you can chuck on a smaller pulley as well
  18. #18
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    better than w2A how so? or you reffering just to the ones available for l67's?
  19. #19
    Adam_88's Avatar
    red VY Ute
    Nov 2008
    canberra
    if you put a w2a with a seperate cooling system with an ice box it will be way better than any a2a. you could also put a methanol injector into the back of the throttle body to cool the blower then you can run more boost
  20. #20
    Mar 2008
    That's a good idea really - W2A intercooling is a lot more efficient than A2A when done properly. Regardless of the methanol injector that poor little blower will be running way out of it's efficiency range so I suggest leaving the boost at the current levels.
  21. #21
    Adam_88's Avatar
    red VY Ute
    Nov 2008
    canberra
    Quote Originally Posted by one_and_only2004 View Post
    agreed, id be saving my pennys for a whipple and aluminium heads
  22. #22
    Blown VS V6 Wag
    Jun 2005
    East Side Syd
    Definitely not planning on pushing baby blower an harder.
    Totaly forgot about meth/water inj decent kits are about $400 i think?
    Damn more options!
    "W2A intercooling is a lot more efficient than A2A when done properly." So do mace do it properly?
    I've spoken to them a couple times, use and rate their TBs, & MAFs but would like someone who has one of their W2A coolers opinions
  23. #23
    Mar 2008
    I haven't dealt with their blower applications but I always thought they just sold the plate that goes in between the blower and the motor, and you make up your own intercooler setup. My old ute was tuned through chiptorque and they said A2A intercooled top mount blowers go a bit funny due to the throttle being before the charger (I didn't really know or care what they were talking about at the time) but they said they were on top of it - and this was close to a year ago.
    W2A intercooling is a lot harder to make from scratch too - you've got your radiator, pumps, reservoirs, Intercooler and plumbing to worry about - which is also a lot of weight. You loose about .2psi through the system though, which is very efficient. I've seen some systems with a 1% pressure drop on the internet.
    A2A requires an intercooler and plumbing - I managed to get a mate of mine in Brisbane to do the whole thing for me, it cost $1500 using stainless steel piping TIG welded including all the brackets and intercooler. It lost about 1psi in a 10psi system, but gained about 60NM of torque. using silicon and alloy piping you could do it for a fair bit cheaper I reckon.
  24. #24
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    air to air is the best way for the street theres so much air round to cool your charge water to air is good if you can keep the water cold with ice but most w2a kits for l67 are a restriction in the inlet under the blower its only a small hole under there why block it with a radiator in there LOL.i myself would stop spending money on the charger and sell it heads and all and go turbo like suggested above youll gain more than your 50Hp extra straight away LOL
  25. #25
    NA 3.8 VS Ute
    Sep 2009
    No fixed address, Auckland, NZ
    My 2cents would be turbo
    But that depends if you like the superchargers early torque addition or want to chase more hp.
    I saw a clip on youtube of a guy in the states blocking off the water gallery from the lower manifold into the S/C. (This lowers intake air temps a little of the S/C and T/B).
    Do the Aussie M90's have this water gallery to block off?
    "Life's a dare, push yourself, F#@k it you might like it. Live on the edge. It could all stop tomorrow"
    - Jimmy Barnes twitter March 2011
    3.8T Wagon
  1. noise from front left tire when turning left. help plz
    By 17UCK! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2011, 09:20 PM
  2. VP rear/left wheel shudder upon hard acceleration turing left.
    By sirsmokeallot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2010, 02:51 PM
  3. Running at 2700 rpm
    By GILow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2010, 04:32 PM
  4. Bt1 Ex Cop Sedan $2700 Ono
    By TRICKEDUP in forum Vehicles For Sale
    Last Post: 11-07-2008, 09:03 PM
  5. VT stalls When Left idle or stuck in traffic
    By orac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2008, 09:21 PM
