Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
Like Tree2Likes
Thread: SIDI V6 and turbo
  1. #26
    2010 sv6 ute
    Apr 2011
    australia
    thanks, i didnt really think it would hurt the resale
    im just curious as to what kits would fit the engine? or would i have to make my own? i wouldnt mind doing it, i think it wiuld be quite a good learning opportunity, maybe people here could steer my in the right direction as to what gear i would need etc
  2. #27
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    i personally wouldnt do a homejob on a newcar like that save up your money and do everything propper dude.
    it is hard work need alot of engineering skills
  3. #28
    2010 sv6 ute
    Apr 2011
    australia
    its not like i would be doing it all myself, thats way over my head, i was just wondering what setup i should run? stuff like what turbo, amount of boost etc
  4. #29
    Jul 2010
    Get a Garret gt35/40 take your car to a performance place that makes manifolds get that done and the dump pipe connect your oil/water lines etc cooler and piping then go get a tune basic as I can say it lol
  5. #30
    2010 sv6 ute
    Apr 2011
    australia
    yeah i i understand that, any suggestion on intercoolers? what about fuel injectors i will need to upgrade them wont it?
    also what should i aim for eg rkw and boost?
  6. #31
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    I'd be looking at a 500x300 intercooler, gt35/40 turbo (as mentioned), 50lb injectors, in tank high flow fuel pump.
    Run about 8psi - that should get you easily up to the 300kw mark. You might be able to run more boost on them, but the alloytecs are a NA motor (fairly high comp) so unless you lower the compression you're asking for all sorts of trouble.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
  7. #32
    2010 sv6 ute
    Apr 2011
    australia
    thankyou can you get 50lb injectors for SIDI engines? i will kep looking
    also is running a gt35/40 turbo at 8 psi to low? i was also thinking of using a HX-40
  8. #33
    Mar 2008
    Quote Originally Posted by bonfield View Post
    8psi should be fine on a 35/40, a 35/40 is an XR6 turbo so it'll spool up pretty quick too. I have no idea what a HX-40 is so you better put a link up.
    As for the injectors I'd have no idea. Easiest thing would be to compare them to a normal alloytec injector and see if they're the same.
  9. #34
    2010 sv6 ute
    Apr 2011
    australia
    HX40 i havent brought the car but there should be some documentation on it somewhere, any idea on prices for these turbos? i was trying to figure out a price for this see what i can afford
    also what are the advantages/diadvantages of lowering compression in alloytec engines? and what are the risks?
  10. #35
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    you might even be able to locate someone who is very interested in progressing thier business into SIDI kits who will do you a discount, it has happened in the past.
  11. #36
    2010 sv6 ute
    Apr 2011
    australia
    Really? What are the chances if that happening? If anything i would have thought it was going to be really expensive just for the fact no one is doing it
  12. #37
    Mar 2008
    "Developed for 7 to 10 litre engines operating in the medium/light heavy automotive sector this Holset turbocharger has many of the features found in the Holset heavy-duty range of products."
    It's a truck turbo designed for 7-10L motors. Are you joking about using this on a 3.6L commodore???
    Higher comp = better off boost drivability, less capability for high boost high end power
    Lower comp = more sluggish off boost response, more capability for more power up top with more boost.
  13. #38
    2010 sv6 ute
    Apr 2011
    australia
    My bad someone mentioned it to me and I was in a rush an posted the first link, no chance that is the correct one, am I right in saying all I really need is a turbo, intercooler oil lines piping etc and a boost controller? Plus a tune and upgrade stuff like fuel pump, injectors probably pistons and rods to?
  14. #39
    Mar 2008
    Ideally yes you're right, but I'd just run 8psi with stock rods and pistons and see how that goes.
  15. #40
    2010 sv6 ute
    Apr 2011
    australia
    No need for an intercooler? I didn't think it was going to be that easy, I suppose I'm not really running it with massive amounts of boost
    What do you think the safe limit I could take it to before having to upgrade the internals?
  16. #41
    ve series 2 sv6
    Sep 2011
    wagga wagga
    if you have a look on st turbos its an american company they make a turbo for the 3.6l v6 camro which is the the same engine as the ve im not sure if they ship here but email him it would be interesting to the price is about 5000 with an intercooler etc
  17. #42
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    ^^^^ thats a cheap price. Makes me interested lol
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
  18. #43
    VE Series II SV6
    Dec 2011
    Concord, NSW
    Is this the one you mean - Squires Turbo Systems - 2010-2011 V6 Camaro ?
  1. Sidi v6 vs R33 skyline turbo
    By Ed in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-08-2011, 07:15 PM
  2. Turbo for the SIDI on sale in the US
    By Jarp in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-03-2011, 09:16 PM
  3. SIDI kit for VZ
    By VzVzVz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-05-2010, 11:53 AM
  4. Ve ss sidi ???
    By ozi_musl in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-12-2009, 05:44 AM
