Results 1 to 14 of 14
Thread: VX S2 L67 how much boost can you safely run?
    2001 VX S2 Calais 3.8V6 S/C
    Apr 2006
    Christchurch New Zealand
    Default VX S2 L67 how much boost can you safely run?
    Hi guys, first of all hi from Christchurch NZ as per the thread title i have a VX S2 Calais L67 with a modular hub and 10psi pulley installed from mace and a complete cat converter removal replaced with strait through tubes on each side apart from that this is the only mods i have done to it, the motor is standard otherwise, i am wondering how high boost i can run before i risk serious engine failure, and are these things prone to lunching them selves at hight boost levels i always run at least 95 octane and service it every 6,000kms with full synthetic oil, just wondering how high i can safely go in the boost and any other suggestions to slightly improve the performance that are not too difficult to do? my old man has just brought a Merc C32 AMG and i would like to keep up with it thanks in advance.
    Scotty
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Hi there boss, we just had a fella in this thread Help stuck at 230kw only $2700 left in budget chasing more power through higher boost through his blower. If you have a read there you'll find that you're pretty much peaking the efficiency of your supercharger, and if you go any higher all you're going to do is generate more heat and well... that's all.
    I'd recommend intercooling and installing a cam. MACE engineering (a site sponsor here) can supply you with the gear you need.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    People say 10psi uncooked max but I've hear of 11 or 12 max really depends
    Apr 2006
    Mar 2008
    I can't comment on the bigger MAF's, but I used to have a 69mm throttle body on my supercharged V6 and it didn't really do anything at all.
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    ive run a 12 psi pulley on mine un-i/c, made a bit more torque but judging by the amount of unburnt fuel coming out the exhaust, the ECU is pumping the fuel in to try and keep the temps down
    vt ss v6 supercharged
    Dec 2010
    new zealand
    hi i have a 73mm pulley getting 13psi boost, torqueperformance.co.nz chip, headers and strait pipes, 4inch intake, mild cam
    Apr 2006
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    un-tuned 10psi is generally the safe limit. if you want to run more psi then intercooling and custom tune is the way to go. there are guys running really small pulley's (19psi) with the A2A intercoolers on otherwise stock bottom ends. running a decent cold air intake helps as well. plenty yet that can be done. a cam swap would help, speak to Steve @ MACE
    Quote Originally Posted by one_and_only2004 View Post
    that guy is running a stroker with a cam so is a different kettle of fish
    Body by Holden, Soul by Brock
    the Legend will live forever
    Apr 2006
    Auckland NZ
    Quote Originally Posted by rocketscott View Post
    im thinking of going for one of these Front Mount Intercooler and Plumbing from Forced Induction Technologies - Australia's V6 Supercharged Specialists any good? what are they like to install?
    he just on-sells MACE products. i'd use MACE, his service is much better
    VS ute
    Nov 2008
    sorry to steal your thread for a sec but how much boost from a turbo do you reckon the l67 bottom end could handle? 16psi?
    Apr 2006
    Auckland NZ
    FIT made about 440rwhp on a stock L67 with the M90 removed and a turbo kit fitted @ 20psi
    i'd take anything Tony says with a grain of salt though
    NA 3.8 VS Ute
    Sep 2009
    No fixed address, Auckland, NZ
    Quote Originally Posted by immortality View Post
    This might just be gossip.. but I heard FIT went through a few engines perfecting their tune.
    "Life's a dare, push yourself, F#@k it you might like it. Live on the edge. It could all stop tomorrow"
    - Jimmy Barnes twitter March 2011
    3.8T Wagon
    Apr 2006
    Auckland NZ
    who knows. i don't think 20psi is excessive, the trick seems to be a good fuel system and a good tune. don't get to greedy with timing. hell there is a guy on Street Coms forum who runs 19psi on a stock bottom end VR V6 and only blew the head gaskets when it boost spiked to 21psi.
    But like i said before, take anything for FIT with a grain of salt
  1. [WA] Wanted: Boost gauge,boost controller, ev6 36lb injectors and walbro in-tank
    By H1GHROLLR in forum Swap / Wanted to Buy / Trade
    Last Post: 11-06-2010, 04:42 PM
  2. How to safely handle oil?
    By YMMB-AME in forum The Pub
    Last Post: 18-05-2010, 11:46 PM
  3. Can I safely discard my IAC sensor?
    By VSSECO in forum V6 Development And Modification
    Last Post: 17-12-2008, 05:02 PM
