i was just wondering if it was worth doin a lumpy cam or crow cam iam not sure and dont really know what i have to do and what i need and how much help thanks![]()
Top right corner... 'Advanced Search' click that and type what u want in the search engine. This topic has been covered a few times!
...But in short. The old "stage 3" crow was pretty small. I heard that they changed the "stages". CBF looking for the crow site tho
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
It's still small,
But I have one and with 3.9's it's still lazy out the hole.
So if you do go that path get a converter as I'm now putting 4.11's and a 2800 converter.
That will wake it up.
Don't think crow do stage 3 anymore for ecotec. what about talking to mace in the sponsors section top of forum page.
Originally Posted by Yoda
http://www.crowcams.com.au/media/cat...olden%20V6.pdf
Even the 8531563T cam is small.
Ronald Reagan (1986)
oh ive got no ecotec h8 them... ive got the good old solid oneif ya know yer i will do or iam just thinking just to turbo it or charge it iam not sure :S
Turbo or Supercharge beats Camshaft.
yer iam just not sure what one what one would cost more ? and what would be better with out doing much to the engine ?
Turbo or supercharging will cost way more.
Nothing. Leaving the engine standard.
What is your budget and how much of the work can you do yourself?
Cheers,
Steve
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
A slight off topic question ( im good at that! ) the L67 has the cam gear set at 2degrees advanced, so would there be any benefit to running the L67 cam gear in a non supercharged eco since their the same bump stick?
MaceEngineering
MaceEngineering
for what a 5L is worth these days...
New cam, memcal, springs, retainers, double row timing chain set to suit will be around the $1100 mark. If he was on a real budget can supply a comp cam and memcal to suit for $680, which would work well with everything else. If boost or an engine conversion was on the cards(?) then I guess a factory supercharged V6 would be something to consider.
Cheers,
Steve
MaceEngineering
Its been quite some time since I was last on Just Commodores. Was just checking out the scene & it was great to see things are still going strong with the interest and development of the V6 engine.
A few years ago now I did have some fun with a V6 ecotec in a VS Commodore and throughout the entire build up was facinated by the results and potential of this engine. Just saw this thread & thought I might relive some past moments.
It became apparent to me that the V6 was really detuned, so to speak, from the factory to make it suitable for the average grampa driver and with just few clever modifications, there is just so much potential that could be unlocked.
So, is a camshaft upgrade worth it................?? The answer is a very confident YES. However, it must be done right. The camshaft must be carefully degreed in. I found the the factory valve timing was chronically retarded from the factory. I had to advance the camshaft 6 degrees just to get anywhere near the cam card and I could have gone another 2 degrees I believe however, just played it safe in the end. I did use a Crow stage 3. If I was going to go to all this trouble I wanted to make a difference that would count so a stage 2 kit was never really considered.
Aside from the camshaft I installed Pacemakers, Haltech piggy back and essentially just a few more small mod's.
Conclusion........... The difference was bloody amazing..................!!
An interesting observation was that in the end the final tune was not that far removed from the factory settings. Upon the first start up the engine wasn't happy however, it soon sorted itself out after a few minutes with the factory ECU quickly adjusting itself to the new engine. I guess the old settings stored in the ECU, inparticular as the last time it run was with the old camshaft were completely inappropiate for the new changes.
Before power: Approx 100kw After power: Approx 135KW Rear wheels.
The best part of it was the on road difference.................... explosive accelleration......!!
I actually created a web site for the build: My Street Car I think its still active. In the end the whole project was abanded due to illness, the car was placed into storage and I had to close my business. Things started to improve for me eventually and the car was put back into service and is still now my daily driven vehicle I use now as a daily driver and it is used to promote my new business. Its a great car and a great engine. The car still attracts plenty of attention and you really now there is something going on under the bonnet. Infact, it just seems to keep getting stronger.
I never actually got to the 1/4 but the temptation remains. I will soon be taking it of the road for a freshen up (Not the engine, its fine) and will be building a new exhaust probably 3 inch and bigger cat.
All in all.............the development never went far so I feel I only scratched the surface of this engine's potential.
At the moment I am involved in setting up the odd circuit car and one critical aspect of making cars going around corners fast in less weight. Yes, weight is a killer when trying to win races. I feel a strong V6 would be a great engine for this category of racing and if done right might even give the STI's & EVO's a fright.
Anyway, drifting off on a tangent hear .....
I could quite rightly get shot down in flames hear................... However, I support a camshaft upgrade over high ratio rockers. I think HR rockers are a great low cost / low time input upgrade although there is almost double the potential outcome with a camshaft plus you also get to play with valve timing when replacing the camshaft. HR rockers will also place extra stress on the valve train.
Anyway, its all good if your having fun
Its good to see your back onto your feet MyStreetCar,I followed your build all the way to the end.I even decided to rebuild my car to your specs and man the car was awsome but sadly it was stolen so I hope you enjoy your car again and happy motoring cheers.
Sorry to hear that your car was stolen gem05,I saw it a few times around town and it was a mad sounding and looking car mate its a shame its gone after you spent $$$ on it,I hope you got insurance back on it.
@coreys912516 i have the same problem i just don't know if it will be worth it or not
@MyStreetCar i came across your website a couple of weeks ago after looking on web sites to rebuild my VS engine and it is that good of a right up im going to do the same i just have to work out money stuff be for i do it.
darcycammo,gem05 did his car to mystreetcars rebuild and last time I spoke to him it cost him $15000+ but then his got pinched by some low mungrel.
