Results 1 to 6 of 6
Thread: Aftermarket ECU for Alloytec? Variable cam timing seems to be the issue...
    EL Fairmont
    May 2011
    Taree, NSW
    Post Aftermarket ECU for Alloytec? Variable cam timing seems to be the issue...
    Ok, now I know what you're all thinking "Alloytec aftermarket ECU? The unit in the car can be flashed!" or something along those lines.
    Well, lets get to the point, I'm a ford guy, buying a Holden Gemini Panelvan. Planning on doing the V6 conversion. Now I know it's pretty straight forward with the ecotec, but it only has 130kw or something in that ball park.
    The alloytec engine is much more appealing, with 180 odd kws at the flywheel. Getting it into the gemi means an after market ecu in my mind, as I dont want to try making a mess of a loom and trying to retain the factory ecu (although, this might end up being the way to go... Although I hope not...)
    So, what can I do? Is there an ECU that's going to run this engine and it's variable cam timing without being overly expensive? Whatever it is I do plan on installing the ECU myself, so something with a pre-loaded tune on it for the engine would be muchly desiered. I thought I'd ask here as you guys would have the most knowlage when dealing with these engines.
    Let me know, what are my options - Thanks, J.Coble.
    VZ Lumina 4sp
    May 2011
    If i was you, i'd get a Ecotec from a vt (Or similar) as they have about 147flyKW. Ecotecs have MUCH more options for modifications. CAI, lifts,springs, cams, memcals, rockers, the list is pretty big. But with a alloytec you have, what, cai, manifold, exhaust?
    This didnt answer your question, but i think you might wanna revise your engine selection.
    Quote Originally Posted by Ryley View Post
    Hahaha, all you need now is a unit sticker; extra 600HP.
    SS Catback
    MACE Cold Air Intake and Insulators
    147rwkw
    VY S Series 2
    May 2010
    the ecotec would be eaiser theres no doubt but then i dont think he's doing the conversion because its easy
    id say you should be able to find someone who could do something for the alloytech... talk to mace as i know he is able to tune the newer alloytechs so he might be able to help you out
    VY SS Ute
    Jan 2011
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    VZ
    Oct 2010
    Have you made any progress on this. I am interested in how you are going to do the mod. I am going to do similar into an EH.
    Glenn
  1. Alloytec Timing Chains replacement
    By Chaney in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-06-2011, 02:51 PM
  2. vz v6 alloytec aftermarket head gaskits
    By v6rick in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-02-2011, 07:11 PM
  3. Aftermarket MAF for Alloytec
    By VZ_SV6_NZ in forum V6 Development And Modification
    Last Post: 23-08-2008, 10:54 PM
  4. Variable effort or variable ratio?
    By Timo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2007, 07:44 PM
  5. Alloytec aftermarket modifications?
    By steane in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-08-2005, 03:10 PM
