Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Like Tree1Likes
Thread: Ecotec Rebuild
    VY II V6 Crewman 04
    May 2011
    Penrith
    Default Ecotec Rebuild
    Hi, I have tried using the search, but it didn't really help me. If anyone can help out a beginner, it would be very much appreciated.
    What I want to know is what I would need to rebuild the engine (has about 150k on it) and change out whatever I need it can take a supercharger a few months down that track ( i found some threads that mention pistins ect). Also a ballpark figure for that parts, and also getting someone to rebuild it for me as I'm not quite that confident yet. Just wanna now what $'s I'm up for. Cheers
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    why do you want to rebuild it? it is only just run in ! as for the cost it all depends on haw far you want to go
    VY II V6 Crewman 04
    May 2011
    Penrith
    Sorry mate. I meant 150k as in 150,000 kilometers.
    I don't want to go too nutz with the rebuild, just want to get the crewman moving quicker. (already done a few of the basics, exhaust, extractors, cai, throttlebody ect...)
    I have seen on other threads about rebuilding the engine to handle the extra power (new pistons, con rods ect..) just wanted to get a few ideas from more knowledgable people than myself :-)
    Munz's Avatar
    Munz is online now Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    I wouldn't bother with the rebuild until she starts to struggle and as long as you have enough fuel in the cylinders and don't run any more than 8-10psi you should be right!
    What charger are you going to run
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    read this ** Rebuilding a Stroked/Turbo VT Ecotec ** although it a stroker it the principles are the same. cost will be similar except you will have a workshop assemble the engine (which won't be cheap)
    Talk to MACE ( in the sponsors section) about pricing for parts that you may need
    cheer
    edit: i see you have a crewman, there heavy, torque is your friend, a blower or stroker kit (or both) is the best way to improve torque
    Body by Holden, Soul by Brock
    the Legend will live forever
    VY II V6 Crewman 04
    May 2011
    Penrith
    Thanks for the replies guys.
    What would be the best? Buy a block and start with that or picking up a rebuilt ecotec and then change out parts?
    Also is supercharge the way to go, or should I go down the turbo path?
    Immortality, now that I looked into it, stroked will probably be a path I will go down for the extra torque.
    I will pm mace and also get there opinion, prices ect...
    Cheers again :-)
    VY II V6 Crewman 04
    May 2011
    Penrith
    One more question, I have been told that the engine in the crewman are raised higher for more ground clearance. I don't know if it matters, but do I have to keep that in mind that theres anything I have to do different?
    VY S Series 2
    May 2010
    if its raised higher in relation to the rest of the car then you just might not have as much room under the bonnet for things like mace spacers and it would also mean less room in the engine bay which could make the turbo or blower a little more difficult... i would think that it was just the whole car that was raised but if not you might be able to solve it with different engine mounts
    VY II V6 Crewman 04
    May 2011
    Penrith
    When I was looking for an CAI I found over the radiator ones for vy v6, but there was a side note that it wouldn't fit a crewman or one tonner. When I asked why he said it was because they raised the engine for more clearance for the sump, and the bonnet wouldnt close. But now that I think of it , that still wouldn't affect an over the radiator system unless the radiator was raised?? I will have compare it to a vy sedan
    VY S Series 2
    May 2010
    yeah dont bother with a over the radiator with a ecotec... the intakes in the side so all the benefits are lost but consider getting a cold air intake to replace the standard airbox with
    VY II V6 Crewman 04
    May 2011
    Penrith
    NO RIDE AT THE MOMENT
    May 2011
    New South Wales
    Agree with burnout124 a 150000km motor doesnt need a rebuild,just needs mods all the main components would still be in great working order.
    Turbo VS II 5 Speed
    Jan 2006
    Hong Kong / Adelaide
    I got to about 240,000km before I rebuilt myn, and by then she was very tired. Trust me though, depending if you want to recondition or rebuild will govern the price. We stripped the entire engine down, new everything, heads completely reconditioned with new seals and valves, basically a brand new engine and that was about $3k (and we did it ourselves with no labour and some 'mates rates'). However its been built to withstand the turbo that will be going on it in the next few months.
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    For $3k you could pick up a low k L67 motor with the supercharger all bolt on loom and probably the box as well. Far better then boosting an L34 donk. I picked up one with reasonable ks for $1500 and put it in my VB. A set of extractors, 10lb pulley, high ratio rockers and you are away. Cheap power and lots of low down torque.
  15. #15
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    Turbo is the way to go trust me
    M90 is good but personally after having them both
    turbo 1
    m90= waste of space
  16. #16
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Quote Originally Posted by VBRED View Post
    The guy paid 3K for a full rebuild which would be better than any L67 out there with 100-200,000K's on it.
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
  17. #17
    Jul 2010
    Quote Originally Posted by G.C.Photography View Post
    as the guy said hes a beginner.
    as the other guy said he done it all himself.
    l67 would be the way to go for him for forced induction
  18. #18
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Quote Originally Posted by ToMMMaY View Post
    What makes the L67 better for him?
  19. #19
    Turbo VS II 5 Speed
    Jan 2006
    Again it all depends on what you plan to do with the car. I'm not planning on ever selling the car so I could justify the price, in comparison to say an 87k drop in motor that I would have to work on again down the track. Especially with the turbo it was better to start with a fresh platform.
  20. #20
    Jul 2010
    high/low compression you tell me
  21. #21
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    That's about the only benefit between the two engines, if each engine was brand new! Running up to 10psi through a freshly rebuilt L36 as opposed to a L67 with 150,000K's on it. I would think the L36 would last longer don't you?
  22. #22
    Jul 2009
    Melbourne - SE
    An L67 is specially built for boost from the factory. The only thing the L67 and the L36 have in common is the block. If you are going to boost it an L67 platform is much stronger + go supercharged or turbo.
  23. #23
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    The L67 is not that much stronger from the factory than the L36, the pistons are coated which give the L67 (what Holden and most people out there call it) a stronger bottom end. If they are worn, they're not going to be much better than brand new L36 pistons.
    Plus most bolt on ecotec supercharger/turbo kits out there are designed to go on a stock engine with the 9.4:1 compression ratio.
  24. #24
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    To the OP,
    I think you need to contact people in the know face to face, go to some engine builders (or contact them online) and work out what you want from your engine, where you want it to hit power/boost and roughly work out how much power/torque you want to get out of it.
  25. #25
    Jul 2010
    Rods are also diffrent dude
    The l67 is a way better engine byfar and everybody knoes that
    ofcourse a brand spanking new ecotec engine would be great but if he wants to be running boost hes going in the wrong direction
  1. Ecotec 3.8l Rebuild Kit
    By crash_cradock1 in forum V6 Development And Modification
    Last Post: 21-05-2010, 12:37 PM
  2. Ecotec V6 (Suit Rebuild only)
    By Waussie in forum Parts And Other Items For Sale
    Last Post: 06-03-2006, 03:22 AM
  3. ECOTEC Rebuild, it's now done
    By portercg in forum The Pub
    Last Post: 05-01-2006, 03:20 AM
  4. ECOTEC rebuild
    By Sparkie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-01-2006, 08:43 PM
  5. ECOTEC Rebuild
    Last Post: 28-12-2005, 10:30 AM
