Results 1 to 8 of 8
Thread: L67, Clive Cam
    JLOWE is offline JLOWE
    vs executive s2 1996 sedan
    Apr 2009
    VIC
    Default L67, Clive Cam
    hey
    everyone im in the process of rebuilding my l67 and im trying to figure out which cam to go for. i have had a few people telling me to go for a clive cam and im leading towards it! im just woundering what fedback use guys can give me on clive cams...
    cheers
    VY SII HBD Calais L67
    Dec 2006
    vt ss v6 supercharged
    Dec 2010
    new zealand
    hi i spent 3 mouths doing research xp hot cam was one of the best go to www.l67torque.com • Login if your rebuilding port and polish heads and blower
    VS ute S2 5SPD
    Mar 2009
    Xp hot cam is based on stock heads. If your going to go all out with heads ect get the XP-Z or intense stage 3
    VS L67
    Sep 2007
    BrisVagus
    What are the cam specifications that you are thinking about?
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    Apr 2009
    VIC
    yeah im boring out the engine 30 thou oversize pistons and all new bearings allround im going to put a double row timing chain and up grade to a 10 or 12 pound pully and pacmaker extractors a sports exaust.. plus im sticking with the orignal rollers and leaving it a auto with a stage 2 kit in it, and im just leaving the heads as standered, im just after a nice street cruiser, not something over the top dangerous.
    iv talked to a few mechanics and done some reserch on the clive cams, and supposbly he is very good at his job..
    Dec 2006
    Quote Originally Posted by JLOWE View Post
    Clive cams does have a good rep. So does Comp cams which is the company that grinds the XP Hot cam from billet blanks.
    XP hot cam is perfect for what you've described imo. I run one with worked heads and larger valves etc etc and it's a very impressive cam to say the least.
    Only advantage that you may get from getting a clive custom grind is due to the fact that the car that the XP was designed for is a FWD lighter vehicle than what we have to deal with in the commodore platform here in Aus. Bees dick in it but if the money's good for you then you may have an interesting combo with a custom grind.
    VYII Calais L67
    Apr 2009
    VIC
    thank you very much for the info its very helpful, i love my car and want to do reserch before jumping strait into something
