Results 1 to 10 of 10
Thread: removing engine with gearbox
    96 VS executive series II 'S pack'
    Jan 2011
    australia
    Default removing engine with gearbox
    so my POS manual that i wasted 40 dollars on says that apparently to take out my ecotec i need to take my gearbox out too?
    i used some brute force and ignorance to take my motor out ...but apart from that is there anything evidence to suggest this book is correct? i plan to put my motor in this weekend and dont want to have to find out the hard way that yes the box has to be bolted on the engine to go into the car...
    cheers
    WHII Statesman
    Sep 2006
    Geelong, VIC
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    Quote Originally Posted by SirNemesis View Post
    You can pull it out either way, whichever you prefer. Seperating the gearbox from the engine is the method I prefer, as pulling it out with the gearbox attached generally needs more ground clearance.
    in the other hand i prefer to pull them out together because i hate having to #### around lining it up in the car.
    doesnt really matter which way you do it though, just a matter of preference.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    WHII Statesman
    Sep 2006
    Geelong, VIC
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Motor and gearbox out together is 2 person job, Easier to pull them out individually if working by yourself
    EDIT: in saying that auto's would be a pain to bolt back up yourself!
    Power is measured in DECIBEL
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    We did one a while ago and I had no idea the box had to be married up before being put back in until just now...lol... We did it just fine.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by SweetWagon View Post
    Well you must be either stupid or incompetent. Taken plenty of motor/box combo's out in one on my own. As above though - it's a matter of personal preference. I prefer to pull out the lot as I can clean up all the grease/oil/dirt on the box before it goes back together much easier.
    Auto's are pretty straight forward to line up in the car but I waaaay prefer fitting a manual out of the car, particularly if you have changed the clutch whilst it's out.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Pub247's Avatar
    Pub247 is online now Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I just did a gearbox change last weekend due to mine being coluum shift it would have been easier to remove as one unit but i normally do them seperatly i find with auto putting them back in is easy especially if you unbolt the torque convertor at flexplate. manuals can be a pain sometime when trying to line input shaft up
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Reaper
    Perhaps i should rephrase, I was able to remove them myself but re-installing was much harder doing myself, I had to wait to get a helper to assist lining up the engine mounts, would have prefered to install the motor by itself I think it would have been easier.
    Jan 2011
    australia
    yeah it went back in it no worries it was just a bit of a bugger to align it. max ellery manuals are USELESS
  1. Easiest way to replace a VP 3600 Clutch fork without (removing) gearbox or engine?
    By grim596 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-10-2010, 05:44 PM
  2. Removing Shifter from Getrag Gearbox
    By antelopeslr5000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2010, 08:12 PM
  3. removing manual gearbox vt s pack.
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2008, 04:35 PM
  4. help on removing a/c when removing engine
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2008, 02:19 PM
  5. removing auto gearbox plumbing
    By dagsy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2007, 12:17 PM
Tags for this Thread
