Results 1 to 5 of 5
Thread: VR - VS Part "Swap-ability" questions
    93 Vr Acclaim
    Aug 2009
    Question VR - VS Part "Swap-ability" questions
    Hey guys, I just became the proud owner of series 1 v6 vs executive! It's auto though
    I also have my vr just sitting about collecting dust, with some good parts though, and I have some questions that perhaps you gents could help me with?
    1. The vr has a T5 in it, will the t5 bolt up to the ecotec using the parts from the vr?
    2. If so will I need a new flywheel or will that bolt up too?
    3. Both the vr and the vs are IRS, will the 2 1/2in exhaust from the vr fit?
    4. Last but not least, what about my lowered springs from the vr?
    I did all the work on the vr myself so I can get it done just don't want to do all the work to take it all apart, then find out I need something extra, or that it won't fit in the first place
    Cheers!
    VS Stato l67
    Mar 2009
    Melb
    Lowered front springs will fit. The rears will fit providing they have the same rear suspension setup. So a live axel VR springs will go into a live axel VS, and IRS VR spring will go into an IRS VS.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    VR's are a bit of a dark horse, they look the same as the VS but are massively different in so many ways. Nothing you have mentioned above is effected by this at all..
    Plug and play my friend, plug and play.
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    only thing that I can think will be affected is the flywheel.
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    93 Vr Acclaim
    Aug 2009
    Thanks guys! I had a feeling I might have to get a flywheel to suit. I seem to remember reading somewhere that the ecotec has 8 bolts not 6 but I wasn't sure, I've never worked on one! To tell you the truth I'm a bit sad about taking my vr to bits, after all the memories (and smoke!) we've made together. Call me sentimental....
  1. [NSW] FS/SWAP: Custom 16" VE Interceptors for Pre-VE cars. 16x8" & 16x7" & Tyres
    By VKCOMMO in forum Parts And Other Items For Sale
    Last Post: 22-05-2011, 06:01 PM
  2. [NSW] FS/SWAP: Custom 16" VE Interceptors for Pre-VE cars. 16x8" & 16x7" & Tyres
    By VKCOMMO in forum Swap / Wanted to Buy / Trade
    Last Post: 10-05-2011, 11:59 PM
  3. F.S/SWAP: 15" Clarion Sub. 2007 Model #PXW1552. Swap 12" Sub
    By GLDNVL in forum Parts And Other Items For Sale
    Last Post: 09-09-2007, 10:57 PM
  4. Questions regarding VR wagon smokey engine and power steering "hiss".
    By jayseventwo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2005, 01:32 PM
