Results 1 to 6 of 6
Thread: Getrag Dual Mass Flywheel Spring Specs
    VSSECO is offline Underdog rebuild
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    Default Getrag Dual Mass Flywheel Spring Specs
    Can someone tell me how much movement is allowable for a getrag dual flywheel. I've got one here that I can twist slightly by hand and it springs back nicely, I think it's in good nick but is there a limit listed in the manual or something to determine whether a flywheel is getting worn?
    *** FOR SALE ***
    4.2L Buick V6 Billet Stroker - Built for big boost
    HUGE $$$$ SPENT - Selling well under half of the build cost
    http://cgi.ebay.com.au/ws/eBayISAPI....STRK:MESELX:IT
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Getrag dual mass flywheel service limit is 20mm of rotational freeplay.
    Also, don't machine a dual mass flywheel. Once they're warped they're fit for the bin.
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    When you say freeplay do you mean how much it can be turned easily without it springing back? Or the total maximum distance you can twist the flywheel by hand - the problem I have with this statement is how hard am I supposed to be twisting it?
    *** FOR SALE ***
    Aug 2008
    NSW South Coast
    Quote Originally Posted by VSSECO View Post
    ^^^Basically, yes. With the back half of the flywheel held firm so it cant move, just grab hold the front half and rotate clockwise and anti-clockwise. Just use a light/moderate amount of strength by hand (don't need to fight against the spring pressure). Use a bit of chalk to mark the stationary point of the two, then note how far you can rotate it past this point. The 20mm figure is measured along the outer circumference.
    Hope that makes sense.
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    Thanks Cander, you're a champ
    *** FOR SALE ***
    96 VS executive series II 'S pack'
    Jan 2011
    australia
    some guy put a nice dodgy stick weld on mine so that it could be machined. nothin wrong with it!
  1. Dual Mass to Solid Flywheel Conversion, Who Can Help?
    By social in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-05-2011, 09:34 AM
  2. Dual Mass or Rigid Flywheel?
    By Zarconia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2011, 08:39 PM
  3. Resurfacing dual mass flywheel?
    By VzVzVz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-10-2010, 07:04 AM
  4. Dual mass flywheel question
    By goanna_38 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-08-2009, 05:08 PM
  5. dual mass v6 flywheel
    By vt1998 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-07-2006, 08:58 PM
