Results 1 to 4 of 4
Thread: ecotec l67 convertion
    vr acclaim
    Jul 2011
    crestmead
    Default ecotec l67 convertion
    hi ppl im curious as 2 how much stuffing around it would b 2 do an l67 convertion in 2 a vr obviously the ecu would b different but r the loom an cross members an stuff all different? Also i have a 5 speed behind the buick atm will this bolt up 2 the ecotec/l67 motor
    ban low performance drivers not high performance cars
    NA 3.8 VS Ute
    Sep 2009
    No fixed address, Auckland, NZ
    L67 bolts in the same.
    Flywheel will need to be match balanced to the L67's flexplate, as they're balanced differently.
    Looms are different; L67 injector wiring is longer (and wired individually for sequential fire, not batch fire like the VR), L67 uses two knock sensors (Ecotec L36/L67 use two half the impedance of the earlier VR), L67 uses a MAF sensor in the intake - where the VR uses a MAP sensor from the manifold, so wiring for these is different.
    So comes down to; if you're going to use the stock L67 S/C ECU with MAF - use the L67 S/C loom. Or use the VR loom and ECU with 2bar MAP sensor and custom tune.
    Did I miss anything?
    "Life's a dare, push yourself, F#@k it you might like it. Live on the edge. It could all stop tomorrow"
    - Jimmy Barnes twitter March 2011
    3.8T Wagon
    vr acclaim
    Jul 2011
    crestmead
    ah ok sounds very achiveable its goin 2 b on a budget(aint they all) so its all going 2 b done it me garage the only other thing im worried about is extractors they wont bolt up 2 the ecotec will they alslo i have been told that the bcm is different is this correct? How do i go about changing it if it is
    NA 3.8 VS Ute
    Sep 2009
    Quote Originally Posted by aj2112 View Post
    Ah no, port spacing is different.. change exhaust manifolds/headers too.
    I did miss something!
    3.8T Wagon
  1. vs v6 to 5l convertion
    By rexy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2010, 03:30 PM
  2. v6 convertion
    By deanno in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-11-2006, 11:25 AM
  3. convertion
    By HVXII in forum The Pub
    Last Post: 20-09-2006, 11:19 PM
  4. convertion
    By suicidal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2006, 09:08 PM
  5. V6 convertion into VK
    By ^kicker^ in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-02-2005, 08:27 PM
