Results 1 to 13 of 13
Like Tree3Likes
  • 1 Post By Boonz
  • 1 Post By delcowizzid
  • 1 Post By cander24
Thread: Help with installing new cam and DOuble row timing chain
    VT V6 Berlina
    Apr 2011
    Maroochydore
    Default Help with installing new cam and DOuble row timing chain
    Heyguys I'm rebuilding a ecotec and I have a new cam and double row timing chain from MACE now I'm a bit stuck on how it all goes back together and how I get the timing right on it any help would be greart thanks guys
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    please get a service manual...theres proper instructions in there with pictures of how it lines up..... not something you want to be guessing how to do
    VT V6 Berlina
    Apr 2011
    Maroochydore
    hmmmm ok I get how to put it all back together now but on the new rollmaster the crank sprocket has like 6 different ways you can put it on all with numbers and how to I find out if number one is at TDC?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    slide the keyway slot marked 0 onto the crank keyway then line up the 0 on the sprocket tooth to the dot on the cam sprocket. then go buy a degree wheel and dial gauge and degree the cam to the specs on the cam card that should come with the cam Sole Purpose of Degreeing Your Cam - Kelford Cams heres a how to on degreeing the cam
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Bloody hell you're gain mate, don't even know how to tell when Piston 1 is at TDC and you are trying to install a new cam. To tell if Piston 1 is at TDC, take out spark plug number one (Will be the one on the passenger side at the front) then put like a long piece of metal in where you took you're spark plug out, manually turn you're Harmonic balancer until you feel Piston 1 at TDC, when Piston 1 is at TDC you know Piston 4 will be as well.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VT V6 Berlina
    Apr 2011
    Maroochydore
    Thank you heaps for that should the sprocket fit easy onto the crankshaft or do you have to bash it on lol
    VT V6 Berlina
    Apr 2011
    Maroochydore
    well there is only one way to learn mate and thats to spend a shit load of cash and build a motor from scratch and learning from your mistakes witch also cost you cash lol
    VY S Series 2
    May 2010
    i admire your atitude cause i wouldnt be doing that but wouldnt you want to read up as much as you can first??
    VY SII HBD Calais L67
    Dec 2006
    Quote Originally Posted by vtv6 View Post
    I'm assuming you have a Rollmaster chain? They are the chain to use IMO but do sometimes have a tight fit on the crank. You can linish the inside of the crank sprocket a tad to allow it to fit on the crank easier. There's nothing wrong with forcing the crank sprocket on but it can get stick making it difficult to remove if needed later. Difficult, not impossible
    VYII Calais L67
    VT V6 Berlina
    Apr 2011
    Maroochydore
    Yea I have a rollmaster chain its bloody tight I tell ya even bashing on it with a mallet wont make it budge that far on the crank shaft. I did read somewhere that there is 3 different crank IDs or something and they had to send out the right size sprocket
    Dec 2006
    Always fit the sprocket with a large deep socket to ensure it goes on square and yeah, a little sanding on the inner is the way to go
    VYII Calais L67
    VS S-Pack SII
    May 2008
    Would heating the sprocket up and cooling down the shaft help? (much like how you fit a dowel in a hole)....???
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by PanthaVS View Post
    Yes it would help, but would potentially be a real pain to try and get it back off. It should go on by hand with no more than a light tap. They 'should' be machined for a minimal interference fit.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
  1. vs.. double row rollamaster timing chain
    By crzyvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2012, 10:54 PM
  2. billet double row timing chain ls1
    By johnno010684 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2011, 11:32 AM
  3. Rollmaster double row timing chain
    By IBLOWN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2010, 10:14 PM
  4. [Ecotec] Double row timing chain worth it?
    By maldotcom2 in forum V6 Development And Modification
    Last Post: 07-02-2010, 07:58 PM
  5. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
