Results 1 to 3 of 3
Thread: Help putting ecotec back together
    VT V6 Berlina
    Apr 2011
    Maroochydore
    Default Help putting ecotec back together
    Hi I'm learning as I go at the moment but I just installed the pistons and connected them to the crank and I want to install my new cam shaft and my doublerow timing chain how do I know when cyl 1 is TDC when the piston is all the way at the top? and on my crank shaft sprocket theres like 6 ways it can go on if that makes any sense just wonder what number should be inline with the camshaft timing mark sorry if that makes not much sense at all but I am a newbie at all this and I'm trying to learn
    Pub247's Avatar
    Pub247 is online now Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    First off did you check your clearances?
    Do you cam wheel or a dial gauge? (think its adial gauge my brain isnt working on that one)
    Have you put the heads on yet?
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VT V6 Berlina
    Apr 2011
    Maroochydore
    I havent put the heads on yet and I have checked all the clearances not sure what you mean by the cam wheel or dial gauge
  1. Putting stock HU back in
    By skerik in forum Car Audio
    Last Post: 26-05-2010, 05:29 PM
  2. Putting cluster back together
    By VXHBD6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2009, 06:24 PM
  3. putting headlight switch back together
    By Denno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-10-2008, 01:26 AM
  4. putting fan shroud back on.. on 5L
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2007, 10:50 PM
  5. putting 202's carby back on
    By Bush VB in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-09-2005, 04:25 PM
