Results 1 to 8 of 8
Thread: Aluminium Cylinderheads?
    VY V6 Ute
    Jul 2008
    Cairns
    Default Aluminium Cylinderheads?
    I appears that ZZP droppet the aluminium head from the stock list.
    Now we have to work harder to get the power out of the old cast heads
    VY S Series 2
    May 2010
    i thought mace was selling them still... maybe that was awhile ago though so i dunno
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Mace still has them. It seems zzp are dropping quite a few things they used to stock due to the current economy
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Yes Mace still has them. Yella Terra i think had them at one stage as well. Are you familiar with the difference of the Aluminium heads ? Eg changing plugs when engine hot, washers under head bolts etc etc. They also warp easier and you will need to watch the gasket and so on as the LIM gasket fails due to the alloy intake sitting on cast iron heads. You will have Alluminium heads sitting on Cast iron block so difference in material again. Even though performance will come down to the porting etc, they have fantastic heat properties and great for machining.
    MACE Aluminium heads - Mace Engineering Group
    VT
    Apr 2005
    QLD
    Quote Originally Posted by Dr HaxZaw View Post
    Where do you think MACE get their gear from? lol
    VY S Series 2
    May 2010
    Considering i dont need them and other than seeing them for sale havent looked at them why should i worry about who makes them for mace?
    VT
    Apr 2005
    QLD
    Was helping you realise that maybe Mace were getting them from ZZP anyway, so the flow on effect was inevitable
    VY V6 Ute
    Jul 2008
    Cairns
    Zuma done a lot of R&D in this, not a lot of high performance parts for serious power is available like the cylinderheads for the series II /III, I believe it is all about supporting the companies that make thinks happen, No support, No more goodies
  1. 3/8 aluminium fuel line
    By MAHOOVKV8 in forum Straight 6 Development And Modification
    Last Post: 21-09-2010, 09:14 AM
  2. Cleaning aluminium
    By VL Berlina 5speed in forum General
    Last Post: 09-05-2008, 04:38 PM
  3. V6 Aluminium Heads available SOON!!!
    By Michelson4301 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2007, 09:09 PM
  4. Aluminium radiator cores
    By Tony2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2004, 05:28 PM
