Results 1 to 5 of 5
Thread: vs ecotec
    vs spac
    Oct 2010
    adelaide
    Default vs ecotec
    hi all 2 days ago my vs startet to mis fire then died and wouldnt start checked error codes and got 32 maf, 42 est bypass circuit fault, 47 crank angle ref signal. since then i have put new plugs, new purge hose from throttle body to intake manifold, cleaned throttle body, cleaned intake plenium, replaced crank angle sensor. still mis fires but can start, left bank doesnt seem to fire well.
    dont get error code 32 or 42 anymore but still get 47(crank angle reference signal) any ideas?
    VS S Pack
    Sep 2009
    with the crank angle sensor removed rotate the motor by hand (may need to remove the plugs first) and use a mirror if needed to see if you can see the black plastic piece in the cam gear that holds the magnet for the crank angle sensor. I have heard that these are fairly common to brake - I broke mine removing the cam from my engine
    VS S-Pack SII
    May 2008
    Quote Originally Posted by Trikky View Post
    I believe the black plastic piece in the larger sprocket is for CAM angle Sensing and the sensor for it is mounted on the front of the timing cover...
    I think you can remove the sensor from the timing cover without remover the cover itself. Then... With a torch, shining in the hole that the sensor was in... rotate the crank with a large socket and breaker bar on the main crank bolt (In the middle of the harmonic balancer) and you will eventually see if that plastic bit is still installed (as it should be)...
    When the bit comes into view, you can also test it is still magnetic by touching it with something steel....
    If you wanted to test the CAM angle sensor... do a swap with someone who has the same car/engine....
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Cam angle sensor is just held in by 1 10mm bolt. May need a little jiggling to pull the sensor out as it has an o ring seal around the outside of it. Nothing else has to be removed to remove it. A faulty cam angle sensor however should not cause these symptoms.
    Have you tried to identify which cylinder is causing the miss? With the engine running, 1 at a time, remove a plug from an injector. If removing the plug worsens the idle, put it back on and move onto the next as that cylinder is working fine. When you get to the cylinder that removing the injector plug doesn't change anything, then you've found what one it is.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    vs spac
    Oct 2010
    adelaide
    thanks for all the replys guy, got it going good again just got new coils, dfi, and leads.
    cheers
    jamsl186
LinkBacks (?)
  1. 24-09-2011, 02:46 PM
  1. rocker covers from non ecotec motors onto ecotec - does it work?
    By Gus The Snail in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2011, 08:57 PM
  2. [NSW] 2003 Heron White VY II S Boot Lid & Spoiler + Ecotec Engine Cover + Ecotec Alternator
    By jr689 in forum Parts And Other Items For Sale
    Last Post: 20-06-2011, 11:26 AM
  3. engine swap from vs ecotec to vr s/wagon(non ecotec)
    By gumby05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2010, 06:33 PM
  4. [Ecotec] ecotec auto to ecotec manual conversion
    By jimmythefish in forum V6 Development And Modification
    Last Post: 12-11-2009, 04:44 PM
  5. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
