Results 1 to 8 of 8
Thread: Buick V6 rev range
    Vp
    Jul 2011
    Briabane
    Default Buick V6 rev range
    Hey all.
    I just installed a tacho in my S2 VP executive and wanted to know what the rev range is? I took it for a spin and at 4000rpm it sounded like it was screaming! The tacho is set to the 6 cylinder setting........
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Yep sounds about right! i thought the exact same thing when i got the tacho in my vk with the VP v6 working, its just the way the old V6 sounds. I dont think ive ever revved it much harder then 4 lol
    91 vn s
    Jun 2009
    Adelaide, SA
    you dont need to rev it harder than 4grand
    but for the op question, my tacho red-lines at 5.5G
    you will hear it on limiter. MANGMANGMANGMANG
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Where is it when it makes no more power & torque?
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    max torque at 3600, max power at 4800, i dont really understand the difference between power and torque, obviously torque is twisting power but what then what is power.
    HoldenManDan's Avatar
    HoldenManDan is offline Built, not bought...
    VS Exec SII 4.2L L67 T56 :D
    Jul 2006
    Penrith, NSW
    from the unofficial holden commodore archive:
    VN buick motor:
    Compression Ratio: 8.5:1
    Maximum power: 125 kW @ 4800 rpm
    Maximum torque: 292 Nm @ 3200 rpm
    VP buick motor:
    Compression ratio: 8.5:1
    Maximum Power: 127 kW @ 4800 RPM
    Maximum Torque: 293 Nm @ 3600 RPM
    VR buick motor:
    Compression ratio: 9.0:1
    Maximum Power: 130 kW @ 4800 RPM
    Maximum Torque: 295 Nm @ 3200 RPM
    hope this helps!
    Factory 5 speed VSII, now 4.2 Litre L67 with T56 6 speed
    Vp
    Jul 2011
    Briabane
    Ok.... Sounds right then. Will sound mint with good exhaust then! Thanks.
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by VK SL 3800 View Post
    Torque is the measure of rotational force
    Power is measure of the rate at which mechanical energy is being produced
    Therefore 100kw at 2500 RPM will be producing twice as much torque as 100kW at 5000RPM
  1. Ve epa rev range
    By holeman in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-10-2011, 08:51 PM
  2. [Ecotec] mid-range cam
    By nalchlan in forum V6 Development And Modification
    Last Post: 29-05-2011, 10:41 PM
  3. [Buick] American buick pistons in VR buick motor
    By aleavy in forum V6 Development And Modification
    Last Post: 03-01-2011, 09:13 AM
  4. High Rev Range
    By Homer's HSV in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-06-2010, 07:42 PM
  5. 25% Off Entire Range
    By Holden_Mechanic in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-12-2005, 08:02 PM
