hey all,
just wondering if anyone has installed one of those DIY Air Intake mods?
I have seen heaps of them on eBay......so I bought one
It claims to increase HP by up to 20HP......in conjunction with other mods.....of coarse.
Its instructions say to install it into the Air Intake Sensor.....
is it safe, does it work?
Mate, Id say it'll easily give you a good 30-40hp or more, definately worth it
Power is measured in DECIBEL
Cop chips work better![]()
Paint your calipers, 25kw easy there
I installed two of them intake things in my Auto vn, it Wheelspins all gears and chirps from 4th to 5th. Definitely recommend it.
Hey mate ignore all the haters
the only problem with them is they generate a lot of heat... what you want is 2 methanol sprays just behind it in the air intake. this will help cool the air and also get you a lot more power because methanol burns better than petrol
generally people run 2 sprays for balance however if you can afford 3 theres a lot more power available
Don't forget to tighten the rocknut... **hopes there are some Mighty Car Mods watchers out there**
gotta love the rocknut...
also dont forget to jack up your car if your ever installing a sub woofer
and red powerbands....they are the fast ones
but seriously...all that chip does is make your car think that the air temp is colder then it is therefore it puts more fuel into the cylinders and makes the engine run rich...20kw is an over-estimate...at best i would say maybe 5kw if your lucky
Brembo brake covers 100% better brakeing for under $20.00 . Cop chip = Better manging for the price of a packet of chips.
