Results 1 to 5 of 5
Thread: Catch can and venting
    VY S Series 2
    May 2010
    Default Catch can and venting
    Hey all
    So i've bought a catch can to stop the oil having a party in the plenum and having read a few other threads on this forum i'm wondering a few things
    Is it better for the can to vent to the atmosphere or for it to vent into the throttlebody?
    The reason im asking is that i was thinking of closing off the port in the throttle body and then running the vent from the catch can into my airbox... mainly cause that way there wont be a little filter sitting in the middle of my engine bay and i cant see it being defected for that.
    I assumed this way the engine should run a little better ive heard that it messes the engine up a little bit cause its gets a bit of extra air but the maf doesnt read it.
    This is only an idea so let me know what you all think
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Quote Originally Posted by Dr HaxZaw View Post
    Hey all
    Its illegal to vent to atmosphere hence the best option is to plumb it back into your TB.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Hmmmm...
    It's definately illegal to vent it to the atmosphere so that's ruled out.
    One thing though, my catch can vent is plumbed in so it enters the manifold AFTER the TB so under VAC. If you plumb it in to the airbox, then it won't be much vac.
    Not sure how this would affect things. I just thought I would post this as an observation and let others fill in the blanks.
    Cheers.
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    alot of people vent it to the atmosphere instead of using a filter use a hose to hide it underneath your car.
    VY S Series 2
    May 2010
    i was just going to run the hose into the airbox and put a filter on the end of it... and i thought the only reason you couldnt vent to atmosphere was cause of the filter catching fire (kinda like an exposed pod filter)
    does it need to be under vac or not? i assumed that the breather on the block was just there to stop crank case pressure so whether it was under vac wouldnt make a difference
    I think delcowizzid had a pretty good idea about what was going on but it never made sense to me
  1. Venting Booth
    By DavesCalais in forum General
    Last Post: 18-08-2010, 05:39 PM
  2. just venting
    By metalfossil in forum General Discussion
    Last Post: 01-03-2007, 05:27 PM
  3. Fuel Tank Venting
    By jpetrou in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-08-2006, 08:45 AM
  4. ELDERLY DRIVERS!!! venting my anger
    By cameron boyle in forum General
    Last Post: 23-08-2005, 12:45 PM
