Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By wamboin23
Thread: double row timing chain - balance shaft removal ???
    vn commodore
    Jan 2011
    brisbane
    Default double row timing chain - balance shaft removal ???
    hey guys. im looking at installing a double row timing chain and anti pump lifters. only running a single row rollmaster and brand new stock lifters, i just wanna push the rev range out a bit more. its a fully built 4.2L pre ecotec with a raptor blower. limited at only 6000rpm. ive heard the stock lifters are only good for a little over 6gz before they start to pump up.
    and do i need to remove the balance shaft to fit the double row chain in ??
    cheers
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    remove the balance shaft and you'll need to block the oil feed to it in the rear.
    if you dont want to go to this extent, you can just remove the gear from the balance shaft and leave it there.
  1. DBL ROW timing chain and balance gears
    By PanthaVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2011, 06:08 PM
  2. balance shaft removal
    By kelvin2164 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2009, 09:05 PM
  3. [Buick] Pre-Eco balance shaft removal experiences/opinions...
    By beeb in forum V6 Development And Modification
    Last Post: 01-08-2009, 08:25 PM
  4. Balance Shaft Removal
    By VPCalais38 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2008, 05:51 PM
  5. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
