Results 1 to 3 of 3
Thread: Mod problems :(
    VT II Berlina L67 A4
    May 2006
    Ceduna, South Australia, Australia.
    Default Mod problems :(
    Finally booked my car in (VT, L67) to fit the following...
    10 psi YT press on pulley with larger idler
    1.95 YT roller rockers - The rocker gaskets were leaking anyway so I thought I might as well get it on all done in one hit.
    YT CAI
    FIT 4 inch MAF ducting and relocator
    Colder plugs gapped to 1mm
    Hi-Fkiw 91c Thermostat
    HSV XU6 Chip
    MACE 25mm Manifold Insulator
    1 5/8 inch to 2.5 inch stainless extractors
    2.5 inch twin metal cats
    2.25 twin hsv exhaust
    So 1061 dollars later and I have on:
    10psi pulley - Had to take the hole snout off and put it in a bearing press to change pulleys, tried it with larger idler first but belt wouldn't fit. went back to standard idler and it fit... Something to do with the Insulator raising the Supercharger.
    1.95 YT RR - Went in no worries. Well mostly compared with the other two mods.
    25mm Manifold Indulator - They reckon the holes were 2mm off so they had to drill them out, bolts were too tight and would of split the insulator, and also the Insulator was hitting a bracket at the back (or something along those lines). Which took an extra hour or there abouts.
    Has anyone else had any trouble installing any of these mods?
    Cheers guys.
    Mar 2008
    I can't speak about the other products, however if you there were any issues with our items would have more then happy to resolve or clarify the process over the phone or via email. Still am if it's of any consolation
    If you have any questions please don't hesitate to ask.
    Cheers,
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    May 2006
    Don't think it would of made much difference to be honest... As there were instructions with the Insulator.
    And the work is done now. So I'm just going to have to bite the bullet and pay for what's done... And get the rest of the work done elsewhere.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. VX Problems
    By jessvx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2006, 09:41 PM
