Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By westerlybreeze
Thread: V6 Ecotec Plenum Intake Polishing Question, Does Plenum condition matter?
    VX Berlina SI V6 3.8L
    Mar 2011
    Default V6 Ecotec Plenum Intake Polishing Question, Does Plenum condition matter?
    Hey Guys, So I was looking into properly polishing up my whole Plenum Intake.
    I've already got the cover polished up and now I want to do the Plenum itself.
    The question I have is does the the condition of the Plenum matter?
    I was going to properly sand and polish the inside and outside of the Plenum.
    Since I'd spend a lot of time on getting it perfect my car would be undrivable
    for a while so I went to the wreckers and picked up a whole Plenum off another car.
    Does it matter what condition the plenum is in, would it matter whether I polished up
    my original Plenum that's done 100,000kms or the one from the wreckers that's done
    200,000kms. Since I would be polishing the inside and outside,
    it would be the same piece of metal right? Basically like new?
    So all up my question is, Do I temporarily put on the Plenum from the wreckers on
    my Commodore and polish up the original one, or do I simply polish up the one from the wreckers
    and change them once over I'm done. Since replacing the plenum is a fair bit of work
    that requires depressurizing the fuel lines, I think I would get a mechanic to change
    them for me. Your help much appreciated, Cheers
    Gabriel.
    NA 3.8 VS Ute
    Sep 2009
    No fixed address, Auckland, NZ
    Hi Gabster,
    Firstly I hope this other plenum is the same as yours?
    VS-early VT are grooved to use O-ring type gaskets, where late VT onwards use flat steel and paper gaskets.
    It's not a major, but you'd need to get the right gaskets to suit.
    Also some plenums don't have the EGV for emissions of the side, which could be a good thing depending on the emission laws where you are.
    I wouldn't think a bit of mileage would make a difference, only if it's corroded or damaged. If it were me, I'd polish the one from the wrecker..
    The fuel lines don't need to be disconnected, it is possible to remove the plenum without disconnecting them.
    Good time to fit some Mace insulating spacers!!
    "Life's a dare, push yourself, F#@k it you might like it. Live on the edge. It could all stop tomorrow"
    - Jimmy Barnes twitter March 2011
    3.8T Wagon
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    LOL at de-pressurizing the fuel lines. If you are really that worried about a little squirt of petrol then just pull the fuse for the fuel pump and crank the car over a few times on the starter.
    Cheap, fast, reliable.....you only get to choose two.
    Mar 2011
    The plenum I got from the wreckers has O-ring type rubber gaskets.
    only thing is that its off a VT and mines a VX, apparently the lower inlet manifold casting is different??
    I might have a crack at changing them to see if they fit since the fuel lines don't need to be disconnected.
    and yeah I'm definitely gonna get the Mace spacers
    NA 3.8 VS Ute
    Sep 2009
    Quote Originally Posted by Gabster118 View Post
    Ah yes the crackcase breather hole from the PCV could be in a different place, later models place it towards the centre where early VS-VT is rearward in the plenum.
    Just remove your plenums lid to see and if different, don't use it. See if the wrecker will swap it.
    3.8T Wagon
  1. [VT-VX] Polishing the plenum on your ecotec
    By ANL53X in forum Holden Commodore How-To's
    Last Post: 12-02-2012, 07:16 PM
  2. 96 VS (ECOTEC) Air-Intake Manifold Plenum ####ING FILTHY
    By Nessie1996 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2011, 03:54 AM
  3. ecotec reverse plenum question?
    By MR_VX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2011, 06:16 PM
  4. polishing inside of plenum/intake?
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2011, 09:24 PM
  5. [QLD] [B]Selling Ecotec Intake, Plenum, Injectors And ThrottleBody + Engine cover [/B]
    By BIG-EV in forum Parts And Other Items For Sale
    Last Post: 20-08-2009, 09:59 PM
