Am fitting a VT motor to a VS commodore ute . Realise I have to drill and tap the manifold and refit the SENDER but what is the thread size ?
1/8" NPT. Make sure you use an NPT thread because the sender has a tapered thread.
most appreciated. The tap required is in a motorcraft set. Job done. Back to the rest of the motor.
